Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
c5 a4 launch question
Old Jan 23, 2004 | 09:17 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default c5 a4 launch question
asking for a friend who is tryin out his c5 for the first time........he asked active handling on/off, and competition mode or not???? I told him i thought active handling off.........but I'm a c4 guy........what do I know anyway?? :confused:
Old Jan 23, 2004 | 10:51 AM
chaase's Avatar
chaase
St. Jude Donor '12
Default Re: c5 a4 launch question (My 95)
Use Competition mode (Active Handling On/Traction Control Off)
Old Jan 23, 2004 | 12:31 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I turn off both A/H & T/C!
Old Jan 23, 2004 | 08:23 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Ken, i run in the competition mode. (safety net) Being basically stock (gears & headers) i leave the line at 1200 rpms and mash the pedal. :steering:
Bob
Old Jan 23, 2004 | 08:48 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: c5 a4 launch question (16Again)
I don't think A/H could have helped in this case. I saw it happen at Calispeeway, but I could not tell you if A/H was on or off. The wall is very close .
[Modified by wallstAL, 5:51 PM 1/23/2004]
Old Jan 23, 2004 | 09:18 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I run with both off.
Stock just have him do a very small burnout, basically cleaing the tires off as runflats are very expensive.
Gradual quick accelaration and he is off.
Old Jan 25, 2004 | 08:32 PM
urslooow's Avatar
urslooow
Definitely Both off. Both settings will cut the throttle at the worst time! If he's stock just tell him to floor it on the 3rd yellow. Also very important run in the "3" gear, keeps your rpms higher (throws in an extra clutch pack on A4's).
Old Jan 26, 2004 | 03:13 PM
lostsoulny's Avatar
lostsoulny
Default Re: c5 a4 launch question (urslooow)
both trac and A/H off. Launch in 3rd. do a lil tire spin in 1st. also drop your rears to around 23 and if you want up the fronts to around 40 (for stock runflats)
Old Jan 26, 2004 | 03:58 PM
MY 95's Avatar
MY 95
Default Re: c5 a4 launch question (lostsoulny)
thanks everyone :D
Old Jan 27, 2004 | 10:51 AM
urslooow's Avatar
urslooow
What up front tire pressures are you using for non runflats (with DR's and eagle F-1s in front)
To c5 a4 launch question
