Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Which avatar?
Old Aug 9, 2004 | 11:56 PM
Yano's Avatar
Yano
Default Which avatar?
last fall I ran a best 12.0 at 117.5MPH up here in Colorado at PMI. I think the track elevation is around 5000ft above sea level. Do not have the DA. The conversion factor that day was around .9292 I think(at least someone said that at the track) so that would translate into an 11.2 at 126.5MPH.
I have been using the 12 second avatar, but someone IM me and said hey at your altitude you should get to use the conversion factor and use the 11second avatar.
What do you guys think???
Old Aug 10, 2004 | 10:46 AM
cscollis's Avatar
cscollis
I think I would stick to the 12 sec avatar. Maybe you could drive to a track at lower alt. and knock off the low 11 pass. Until then your car has only run a 12 sec pass.
BTW: Great run at alt., I would be happy to run 12's at 5000 ft!
Old Aug 10, 2004 | 11:03 AM
LOTAHP's Avatar
LOTAHP
Old Aug 10, 2004 | 05:26 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Did you got the track in Denver? There is another track that is a lower altitude which should get you a true 11 second slip.
However, one should not have to go to great lengths to change their avatar so there I say if you want to use the 11 second avatar do it. Heck copy it, add the words, "Altitude Corrected" in fine print and you are good.
Old Aug 10, 2004 | 06:04 PM
Spinal Sh0ck's Avatar
Spinal Sh0ck
Just messed around and changed up my sig and avatar.. if you want one done.. email me a pic or 2 of your car..
Old Aug 11, 2004 | 05:59 PM
comp's Avatar
comp
if i drive off a cliff i'd go over 200mph not yet
Old Aug 19, 2004 | 10:57 PM
Yano's Avatar
Yano
Thanks guys. I should get my car back in about a week or two. Did a H&C so the 11's better be no problem!!!!!!
I went to PMI, I have never been up to Bandimere.
To Which avatar?
