AFR Hydra Rev Kit: Anyone using it?
The cam they are using has .215 of duration on both intake and exhaust. I am using the LPE "219" cam. Here is the rest of my combo......
355
10.8:1 real compresion (verified)
Heavily ported Edelbrock RPM heads (they used to belong to Bowtye8)
Titanium retainers
LPE "219" cam
LPE 58mm throttle body
SuperRam base, runners, plenum
CompCams 1.6 ratio Pro Mags
LT1 injectors
SLP 1 3/4 headers
Vigi 2600rpm converter
3.27 gears
Sorry to list EVERYRTHING but I just want to make sure all my info is on the table. The car is a '89 GTA (about 3500lbs). I know it's not a vette but soommeday........ Ahem, would I show any gains with the Hydra-Rev kit or could my money be spent more effectively? Thanks guys. :cool:
Hydraulic rollers are as good as solids on street when desinged carefully!
joni
[Modified by 03QSZ06, 6:38 PM 9/3/2001]
[Modified by 03QSZ06, 6:39 PM 9/3/2001]
D-Port L98 Heads w/2.02" Manley Pro-Flo Int. Valves & 1.6" Exh. valves, ported, polished, 3 angle valve job.
SuperRam
Accell Superram Intake Manifold
Lingenfelter 74219 Camshaft
1.6 Roller Rockers on both Int/Exh (.560 total lift when added to the cam)
1 3/4" headers
58mm TB
Custom Chip
...I know I'm forgetting something, but we're hoping for around 400hp, 450 ft/lbs, and very very deep into the 12s, possibly high 11s with sticky tires and a better driver than me. :D
Conclusion: i don't think it's necessary, but it's not that expensive and if your motor is still apart, it's not that difficult to install. So why not!!!
My set-up is a solid roller and spring pressure is in excess of 700# open, nearly 400# closed. The intake is still off. Reconsidering whether it makes sense. At $100, seems quite cheap, why not? Where was this purchased from?
As for the comment of the tall valvecovers, what rockers require the taller valvecovers? I think I have pretty much exhausted this subject with the topic here called valvecover spacers for AFR heads. Unless you are using Jesel or T&D shafts, I think you can get most anything under the factory cover with some additional work (excludes girdles). Let me know, I always like a challenge.
Thanks,
Aaron
Two things will make it run out of power at rpm:
1.) Stock lifter collapsing under load at high rpm...aftermarkets are better but the rev kit will prevent it from the start.
2.) The 219 cam can run out of power at 5800-6000 RPM, because it's not really a racing cam, it's an emmissions cam that is slightly more aggressive than the stock.
What I would do (well, I actually did for the most part already ) is call Schneider cams ( 619 297-0227 ), tell them your combo and have them design you a cam. You will be surprised the overall cost for them to custom make a cam will be less than the LPE cam. It all depends on wether you care about emmissions.
[Modified by BBA, 12:33 AM 9/8/2001]
Where I think the rev kit will help is in longevity, and most of all "Top Speed" of your car. Once your in the top gear and can't shift anymore you'll be able to sqeeze more top end MPH out of the car. That all depends on what you want to do with the car. I don't condone driving top speed on the streets, so I don't know where you'd do that. ;) If I had a McClaren F1 I wouldn't take it to 230 mph, but it's cool to know you could. If you are just doing some bracket racing you don't really need it. You must decide. If you have a doubt at all that you might regret not getting it, get it. No one I know likes taking them Super-Rams off and on. :jester
Oops. I forgot to mention that my motor has a little ZZ3 cam in it right now. I believe it's 208@0.05 int. and 221@0.05 exh. durations and 0.484 int. lift and .503 exh. lift. with the Aluminum L98 heads from the next year up Corvette engine for a comparison. My best run was 12.65 @ 109+ on M&H's.
I sold my slicks, but comparing the 60' time difference it should go 12.20's on slicks. Also, I have an Accel DFI piggy back computer that I'm learning so it probably isn't dialed in perfect yet. Like I said up a few posts if the 406 and AFR heads I have sitting here go in the car I'd buy the rev kit for it.IMHO
However, I won't be able to help you with the results because I'll probably sell the IROC and all my parts because I won't be able to keep the Z06 stock. Corvette parts are generally more expensive. Especially superchargers.
Good Luck! :cheers: :D
[Modified by 03QSZ06, 1:14 PM 9/8/2001]
