Hows this for engine?
Old Sep 5, 2001 | 10:46 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Hows this for engine?
How will a LPE 74219 cam and AFR 190 heads be on a zz4 short block auto? I want to later get a super ram, 52mm throttle body, and headers but cant right now. Will the 74219 cam work with the zz4 short block without any other mods? Will the cam wrk with the stock computer? Will the AFR heads be good enough for over 400 horse power with the super ram an headers? Should I consider a new torque converter? The heads and cam are taking almost all of my money so I cant get anything much after them. How much HP and torque can I expect from this combo?
Old Sep 6, 2001 | 11:27 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Hows this for engine? (vettes rule)
My answers are in bold in the Quoted text below:
Should work fine.. I would go with 60cc heads to keep the compression up. you could do 58cc to match the ZZ4 hed chamber though
yes it will work just not to its full potential. if you can get at least the intake base or get your ported out it will help when you install the SR
Yes the ECM will be fine. Your concern will be with the PROM.. it will work not sure how good.. You may want to invest in the tuning equipment and learn to program PROMS yourself
Flywheel or Rearwheel HP? I would yes to flywheel
if money allows yes.. get a viglante, I believ they offer one free stall change so when you go from the LTR to the SR you can get the stall changed as well
I don't do well at guessing HP.. so I won't even try
Old Sep 6, 2001 | 12:10 PM
ralph's Avatar
ralph
i think you have good staged plan. Your final combo will be almost a duplicate of mine. when complete, you should have close to 400hp @ around 5300 and 430+TQ @ 4300. A HPerf converter will help you combo at any stage and is a worthwhile mod. You will almost definitely need a custom prom to make the combo work. You have several people on this forum who have gone down this road before you, so you should be able to get valuable help as you go forward. Good luck
Old Sep 6, 2001 | 05:57 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VII Veteran
Sounds like a sound plan to me. Go for it.
To Hows this for engine?
