installing larger valves BBC
Old Sep 21, 2001 | 12:59 PM
Turbo-Jet's Avatar
Turbo-Jet
Default installing larger valves BBC
how are bigger vavles installed in BBC heads? what machine work is required? Is cylinder head porting req'd to take advantage of the larger vavles? thanks.
(just realized this is a better place to post this topic)
Old Sep 21, 2001 | 03:23 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: installing larger valves BBC (Turbo-Jet)
If you had the 2.19 1.88 heads you can install the 2.25 valves and 1.90 exhaust. There is room. I did this last winter. I think the 2.08 heads will only go to 2.19. Porting never hurt anything except bottom end.
Norval
Old Sep 21, 2001 | 03:49 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: installing larger valves BBC (norvalwilhelm)
Norval
pretty sure my heads have stock 2.08 intakes.
i am curious what machine work is req'd?
porting hurts bottom end? huh?
[Modified by Turbo-Jet, 11:50 AM 9/21/2001]
Old Sep 21, 2001 | 06:50 PM
Lohkay's Avatar
Lohkay
He was saying that porting increases flow and reduces velocity which reduces the ammount of power you'll be doing at low rpm but will increase power at higher RPM.
To installing larger valves BBC
