Roll Bars?
Old Sep 30, 2001 | 04:03 AM
Admiral Blue's Avatar
Admiral Blue
St. Jude Donor '11
Default Re: Roll Bars? (BOWTYE8)
BOWTYE8,
You have mail. :seeya
Jeff
Old Sep 30, 2001 | 09:20 PM
84bronzevette's Avatar
84bronzevette
Default Re: Roll Bars? (91tpi-zf)
91tpi-zf;
do you have a phone # or website for S&W?
thanks; scott
Old Oct 1, 2001 | 10:38 AM
ET's Avatar
ET
Default Re: Roll Bars? (Beach Bum)
Regarding Heat Treatment(Weld Normalization) of Chrome Moly Tubing
Actually,it can be done in place,(but it can get costly),with proper preheat and postheat treatment.All low temperature combustibles must be removed from the weld area.The area to be welded is preheated to specified temperature.After welding, an electrically heated "cuff" is wrapped around the weld area and the temperature increased to the post weld temperature required(depending on weld specs).The weld area(which is monitored by sensor) is then "cooled" slowly by decreasing the temperature over the specified period(depending on weld specs.)Note that I used the term "weld specs"as I do not know the Material Grade\Thickness and machine variables,which are needed to generate the values to write those specifications.This process is generally used in high dollar piping systems and critical application tubular support welds.
[Modified by ET, 7:42 AM 10/6/2001]
Old Oct 1, 2001 | 06:33 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Roll Bars? (ET)
I though pinned sidebar were illegal for SCCA use?
Old Oct 1, 2001 | 11:15 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Just make sure you have room for the speakers, hahahahahaahahahaha. I have one of those folding canvas tops to fit in the back for top off motoring.
Old Oct 2, 2001 | 01:33 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Roll Bars? (Bob86ZZ4)
I have the same bar as Bob, but I have had side bars put in by the shop that installed the bar for me.
Old Oct 3, 2001 | 05:42 PM
91tpi-zf's Avatar
91tpi-zf
Default Re: Roll Bars? (84bronzevette)
www.swracecars.com
Old Oct 3, 2001 | 09:06 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Bad news, I was just over at TPIS today and they are all out of that bar and don't plan to make any more. Jim told me that they just didn't sell enought of them to make it worth their while to make another batch. Bummer.
Old Oct 5, 2001 | 09:56 AM
ET's Avatar
ET
As I am in the middle of designing and fabricating my own,after viewing the pictures of LT401 Vette and Bowtye8's,I have noticed a considerable flaw.
Item 1.The rear supports for the main hoop are placed at a diagonal to the longitudinal frame members.(To allow top storage)
Item 2.The receivers for the rear of these supports are welded to the side of the frame.(To allow ease of construction)
I downloaded the pictures and discussed this with a Structural Engineer at the office. A "hair of the butt" analysis indicates an obvious loss of Section Modulus. :nono: An accurate assesment could be made if you know someone with a copy of StruCad,the ability to use it, and the actual dimentions of the members.
As the object of the Roll Bar is to protect you from death in extrodinary circumstances,you might wish to take this into consideration. :yesnod:
Old Oct 5, 2001 | 12:45 PM
ralph's Avatar
ralph
ET you are very preceptive. I had the same concerns. When i had mine installed, the fabricator was able to connect the rear supports directly to the top of the frame and angle them out and then bent then so they connect near the cureve in the main hoop. I can still store the roof in the back and the rear bars are very near the outer part of the car, pretty much outa the way. It may not look as good as LT401's but i hope it is stronger
Old Oct 9, 2001 | 06:50 PM
Warlock's Avatar
Warlock
Default Re: Roll Bars? (ralph)
Hey Ralph, can we see pics of yours?
Old Oct 9, 2001 | 09:33 PM
ralph's Avatar
ralph
Default Re: Roll Bars? (Warlock)
Sorry Warlock, i have no scanner and no digi camera. Maybe i can get JD 383 to take some pictures at the next corevette challenge.
Old Oct 11, 2001 | 01:57 PM
  #33
J Z06's Avatar
J Z06
Will do Ralph.
