LS1 in C4?
Old Nov 15, 2001 | 05:39 PM
89BP's Avatar
89BP
Default LS1 in C4?
Has anyone out there done this swap? An LS1 into a C4. There are a lot of these available at very reasonable prices and it sure beats the cost of building up my L98. This would be going into an 89 Auto coupe, but might soon put in a 6spd. I already have a Dana44 with 3.45 gears, and a rebuilt 700R4 with a Protorque 2500 lock up stall converter.
Some questions: 1. will it fit 2. what about accessories 3. what about wiring and ECU 4. transmission/bellhousing fitment issues 5. header and exhaust clearance problems 6. proper radiator 7. smog equipment(making it totally smog legal) And anything else that I missed.
Any help would be greatly appreciated
Jeff Cawthorne
Old Nov 15, 2001 | 11:13 PM
HWoods's Avatar
HWoods
Default Re: LS1 in C4? (89BP)
89BP, I replied to your post in other catagory. TracerX of Houston TX has an LS1 in an 84 Vette. Ihave seen the car. It runs strong. Trace posted some notes about his car here a couple of weeks ago. Do a search and you should be able to findit.
Old Nov 27, 2001 | 10:59 AM
vettedan's Avatar
vettedan
It seems like this swap would be a straightforward swap. The engine mounts would have to be modified, since the LS1 mounts (I believe) are more forward.
Dan
Old Nov 27, 2001 | 01:12 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
the bell housing bolt pattern is different,and you may have to use a camaro oil plan because the corvette pan is very wide. your best bet would be a camaro/firebird setup, trans and all.
Old Nov 28, 2001 | 01:15 AM
L79vette's Avatar
L79vette
What kind of prices are you seeing for LS1's? I've seen bare blocks cheap like $500, but not complete motors with the injection setup and the computer.
Given the price of aluminum blocks for regular small-blocks, the LS1 block looks tempting until you start pricing all the stuff to make a complete motor.
The L98 buildup to give more power than a stock LS1 should be way cheaper and easier than the swap. Agree that the swap is cool.
Old Nov 28, 2001 | 04:03 PM
70 LS1's Avatar
70 LS1
Default Re: LS1 in C4? (L79vette)
For anyone interested, I bought my LS1 with T56 for $3600
Old Nov 28, 2001 | 04:30 PM
89BP's Avatar
89BP
Default Re: LS1 in C4? (70 LS1)
Very nice, what a deal. Did you get it from a private party or through a wrecking yard. There are some specialized F-Body wrecking yards, but they want an arm and a leg for their complete LS1's and T56's. One guy quoted me $3,500 for just a 94-97 T56, so using my 1/2 of new price that would mean that it would cost $7,000 new, yeah right. If you got it from someone who can get more of them I would really like to know. As soon as I can sell my 94 I am going to attempt this swap in my 89, once I research a few more issues. If you can find me another set up like you got, I am in.
Jeff
Old Nov 28, 2001 | 04:35 PM
70 LS1's Avatar
70 LS1
send me an e-mail and I will give you the name and number fo the guy I got it from. If you need any help with the install, let me know.
To LS1 in C4?
