Pushrod length problem
LT-1 with LT-4 Heads; RR; double springs; 7/16 Rocker studs
So the ideal length pushrod for my setup (as far as roller against valve tip is concerned) causes the rockers to slightly rub against the base of the rocker studs. This may explain why the original pushrods seemed too long; the builder may have just been a little lazy?
Any guidance from the gurus out there; should I grind .150" from the base of each stud or take the same from the base of each rocker arm?
Any other bright ideas?
Oh - and I have measured it about 4 times using checking pushrods and valve check springs - and I have been careful not to preload the lifters for the measurements.
Thanks!
There's nothing wrong with pushrods that may be a bit long,but if you're short.........something WILL break.Just a matter of when.
