Nos and TURBO??
Old Jan 15, 2002 | 12:33 AM
GShyneDM's Avatar
GShyneDM
Default Nos and TURBO??
sorry..probably a dumb question.. but i am not much of a car modder...
i was just wondering if they can go together?
i thought turbos heat up your engines pretty good... and nitrous would add to it.. and be pretty dangerous...
i dunno.. PLease explain to me.. thanks :)
Old Jan 15, 2002 | 05:03 AM
KLLRVET's Avatar
KLLRVET
Default Re: Nos and TURBO?? (GShyneDM)
Actually, nitrous is an EXCELLENT intercooler. But, you must have a motor built to endure the stresses that come with the two.
Tony
Old Jan 15, 2002 | 10:42 AM
GShyneDM's Avatar
GShyneDM
Default Re: Nos and TURBO?? (KLLRVET)
Tony
AHHh... i see.. thanks :)
Old Jan 16, 2002 | 05:10 AM
GlockLT4's Avatar
GlockLT4
Tony
:yesnod: :yesnod: :yesnod:
Old Jan 16, 2002 | 06:50 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Nos and TURBO?? (Glock'94)
There are tons of Supra guys running a 100 shot on top of boost. Or Grand National guys for that matter. It works very well.
Old Jan 16, 2002 | 08:04 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Nos and TURBO?? (LPDesRoche)
Not only does it help cool the intake, it also helps spool the turbo and reduce lag.
Some of the supra guys run some pretty big turbos, with the 3L 6 it takes a bit longer to spool, so the N2O helps out a lot by creating more heat when it is burned... So all around it seems to work great. Just need a motor that can stand up to it.
Old Jan 17, 2002 | 11:33 AM
C1 CMEGO's Avatar
C1 CMEGO
Default One helps the other
We used an early shot of NOS to help spool up the turbos with a pressure switvh to turn them off at 10 PSI it was a fine line on when to turn on & off as if you got it wrong all you saw was tire smoke it also cooled the charge air temps so the turbo could pack more density into the chambers I always wanted to try a starting with big shot & then tapering off progressivly but the electronics wernt up to it at that time
JJ
To Nos and TURBO??
