I've got a fresh 421 sbc. It's apart for inspection and put together. GM 400 block, Lunati 3.85 Crank, Callies 6.0 Rods.
Crower 875 lifters. AFR 227 heads, T & D 1.55 rockers. Bill Mitchell Motown intake, gasket matched. 10 1/2 CR The only thing you'll need is a cam, carb rings of choice and your accessories. I put the cam in the new engine I built. The carb is also for sale, Pro-Systems carb 1000cfm 4150. Have the build sheet. Engine made 558 horse and 537 torque at the wheels, on pump gas.
$5,500/OBO for engine, can be assembled for another $500.00 Located by Cleveland, Ohio. Shipping or freight is extra.
New Price $4500
Reason: lowering price
Build is not on here. I built a 454 small block. Everything new except the cam. Dart Iron Eagle tall deck block, 18 degree Dart heads and intake, 712 lift and 280@50 on 106 CL with 4/7 swap 11-1 CR 2 inch headers. MSD E-Curve Dist. 1.65 T & D shaft mount rockers, Crower lifters. Should be in the 750-800 horse area, goes to dyno a week from wed.
I've bought 2 carbs from Patrick and found both were running rich as installed. Had to have both set up on chassis dyno to get correct A/F
