Swap pistons/rings from bottom?
Old Apr 20, 2011 | 03:23 PM
Surfer69's Avatar
Surfer69
Default Swap pistons/rings from bottom?
I want to replace my KB hypers with forged. I was trying to make it a simple process and see if it's possible to come from the bottom end.
I'm not sure about how/if a ring compressor would work from the bottom and also can you hone the cylinders from bottom or do the main caps get in the way. I would like to leave the heads and valvetrain alone.
My gut feeling is you can't.
Old Apr 20, 2011 | 04:31 PM
MelWff's Avatar
MelWff
I have never heard of anybody doing it from the bottom, how are you going to hone a cylinder which may have a ridge near the top with the heads on? A ring compressor works on the flat surface of the block how do you do that from the bottom?
Old Apr 20, 2011 | 06:17 PM
Surfer69's Avatar
Surfer69
That's why I'm asking, I thought I heard someone in the past say you could do it. The ridge removal is a good point but this engine is still new so maybe not required. Just want to cross hatch the walls.
Old Apr 21, 2011 | 07:28 AM
BLOCKMAN's Avatar
BLOCKMAN
Nope not going to happen!!!! Plus you may want to check the weights as You may need to get the crank balanced as well
Old Apr 21, 2011 | 11:37 AM
MelWff's Avatar
MelWff
if the engine is new, what problem are you experiencing that even made you think of doing this?
Old Apr 30, 2011 | 03:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
To Swap pistons/rings from bottom?
