desk top dyno guys help
Old Apr 19, 2002 | 03:12 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default desk top dyno guys help
i have an 85 vette me and a buddy built this motor im not very sharp on what i was bying but im learning quick :lol: can you tell what this set up will do hp and torq.
1.58mm tb --- 8.stock fuel inj
2.ported maf --- 9.stock heads semi port/polish 202.160 vaules
3.cut out air lid --- 10.hypertech rotor cap 53,000 volt
4.steel roller tip rockers --- 11.58mm msd wires
5.stock rods --- 12.477/480 lift cam 110 center
6..30 over hyper piston --- comp cam kit 268 (summit)
7.400 cast crank
if you can please run this and give me close numbers to what i have thanks JAY :cheers:
[Modified by jparr, 1:12 PM 4/19/2002]
[Modified by jparr, 6:09 AM 4/20/2002]
Old Apr 19, 2002 | 07:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: desk top dyno guys help (jparr)
Jay, Dyno2000 won't model all those mods but I'll run it up if you give me the cam int/exh durations at .050" or at .002" (I can model either).
Also, it's a 383; what about exhaust system, i.e. stock or headers (size).
Old Apr 20, 2002 | 08:07 AM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Re: desk top dyno guys help (65Z01)
I have stock mufflers and stock cat my cam is a 268h comp cam its 477/480 @50
To desk top dyno guys help
