What else do I have to modify????
Old Apr 23, 2002 | 09:11 AM
chrisvette79's Avatar
chrisvette79
Default What else do I have to modify????
Hi, I´d like to install a Edelbrock 600 Carburator with elec. choke on my 78 small block 5.7 (still everything original).
What else do I have to modify on my engine??? (Intake manifold, fuel line, air filter, distributor......)
Does a edelbrock fit under the regular hood :cheers:
Old Apr 23, 2002 | 10:53 AM
L79vette's Avatar
L79vette
Default Re: What else do I have to modify???? (chrisvette79)
It'll fit under the hood no problem.
It won't fit on your Q-jet intake manifold, though.
Why are you changing to a 600 Edelbrock? Your Q-jet is at least as good and flows 750CFM. A good rebuild on the Q-jet will make it work great.
Where you get into hood clearance problems is when you try high-rise intake manifolds.
Old Apr 23, 2002 | 09:56 PM
79er's Avatar
79er
Default Re: What else do I have to modify???? (L79vette)
What he said. I personally would rebuild the Q-jet and use it. Not only does it flow better it also gets better gas mileage then the Elderbrock, due to the smaller primaries on the q-jet. Also it being original equipment it fits with no mods. needed.
Old Apr 23, 2002 | 11:01 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
Default Re: What else do I have to modify???? (79er)
Q-Jet!!!
:yesnod:
To What else do I have to modify????
