Pre-oil direction
Old May 25, 2002 | 06:51 PM
powerslide91's Avatar
powerslide91
Default Pre-oil direction
Guys,
Rookie question, but when using a pre-oilier to prime the engine, which direction does the drill need to be set? Do I "drill" into the engine, or like I am backing a drill out? Engine is a '96 LT4 if it matters.
Thanks,
Jeff
Old May 25, 2002 | 06:58 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Pre-oil direction (powerslide91)
clockwise :cheers:
Old May 25, 2002 | 07:18 PM
scorp508's Avatar
scorp508
clockwise :cheers:
Yup, drill that baby. :)
Old May 26, 2002 | 12:33 AM
powerslide91
Thanks guys. Starting to get excited. New motor is almost done. Hotcam, new lifters + springs. Headers, new exhaust, ported heads/intake... Should be fun. Went to put in the new aluminum flywheel in today to discover that the bolts are too long. With the holiday weekend, I'm not sure when I will be able to get what I need. Very fustrating...
To Pre-oil direction
