Ls6 heads?
Old Jul 26, 2002 | 01:16 PM
DEAD EYE's Avatar
DEAD EYE
Default Ls6 heads?
Does anyone know the stats on them ie. flow numbers, intake and exhaust? :confused:
Old Jul 27, 2002 | 12:44 PM
mountainmotor's Avatar
mountainmotor
Default Re: Ls6 heads? (DEAD EYE)
I had this bookmarked,have not taken the time to look at it though.
If they are not there,,I will find out for you if you will repost
http://www.chevyhiperformance.com/ed...&viewtype=text
Old Jul 29, 2002 | 12:39 PM
DEAD EYE's Avatar
DEAD EYE
Default Re: Ls6 heads? (mountainmotor)
Thank for that sight but they show the LS1 heads, not the LS6 heads. I appreciate your help. :cheers:
My reason for this is to find out wether or not ported ls1 heads 2.02 in 1.57 ex milled to .035 flowing over 300 cfm with a 10.8:1 compression ratio will make a big difference over stock ls6 heads without headers.
Old Jul 31, 2002 | 06:05 PM
korvetkeith's Avatar
korvetkeith
Its hard to say how much better the heads are alone because they only came on the Z06s with bigger cam and better exhaust. But I estimate that they would be worth 20hp over stock LS1 heads, so you could geuss they maybe flow 10cfm more.
Old Aug 1, 2002 | 12:40 AM
sideoiler's Avatar
sideoiler
That Chevy HP article says the 990's (which were LS--6 service heads I believe) will flow Intake@300 183cfm --@400 233cfm -- @500 264cfm and 292@.600 Exhaust with ppipe is 140,176 198,and 204 cfm at those respective lifts..
Old Aug 1, 2002 | 12:39 PM
DEAD EYE's Avatar
DEAD EYE
Default Re: Ls6 heads? (sideoiler)
Thanks! :cheers:
Old Aug 1, 2002 | 11:47 PM
oger's Avatar
oger
The 291 head (the real LS6 head) has a raised intake floor so that it is superior to any previous head. I can't comment on the 990 I have never had any on a flow bench. The exhaust on iron heads is pretty much the same.
Old Aug 2, 2002 | 03:59 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: Ls6 heads? (oger)
I think y'all better clarify if you're talking about a big block LS-6 or a new LS1 based LS-6.
I started out assuming the latter, but the post went to big block by the end.
Jim
Old Aug 2, 2002 | 05:29 PM
DEAD EYE's Avatar
DEAD EYE
Default Re: Ls6 heads? (427Hotrod)
Jim
I was speaking of the ls1 based head.
Old Aug 6, 2002 | 10:44 PM
gojo's Avatar
gojo
http://www.vetteguru.com/misc/flow.gif
This link shows intake
To Ls6 heads?
