crank storage
Old Sep 13, 2002 | 02:08 AM
bob's Avatar
bob
Default crank storage
I just got a nice forged nitrided crank and won't be doing much with it for about 6 months. I usually just spray sea-doo engine storage spray on journals but wondered what others did.
bob
Old Sep 13, 2002 | 09:25 AM
DeenHylton's Avatar
DeenHylton
Default Re: crank storage (bob)
It's messy but I apply wheel bearing grease to all journals and stand on flywheel-end in a corner of the garage where it will not get bumped. I do not cover with a plastic bag because I do not want the bag to sweat. Deen
Old Sep 13, 2002 | 11:25 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: crank storage (DeenHylton)
I also coat mine with grease, then wrap it in paper towels, pour more oil over it then wrap it in plastic bags. It will last indefinitely wrapped like this. I have stored cams for 20 years like that without any sign of rust.
I lay mine on a shelf but somewhere I read that it is not a good idea to lay cranks down like that.
Old Sep 14, 2002 | 02:57 AM
bob's Avatar
bob
Default Re: crank storage (norvalwilhelm)
Thanks guys
I will put a little more grease on the journals.
bob
Old Sep 18, 2002 | 07:47 PM
Desertvette's Avatar
Desertvette
I saw this question adressed by an engine builder who stored his cranks in 8" pvc pipe cut to length with a cap cemented on one end and the cap just pluged on the other side. He installed the crank, then filled the tube with some cheap generic motor oil such as Walmarts sells, and stored upright . Sounded pretty good
Bob
Old Sep 18, 2002 | 08:07 PM
Rebel w Cawz 2 B's Avatar
Rebel w Cawz 2 B
I use motorcycle chain lube (spray can). When ready to use it, just clean thoroughly.
Someone else said "don't put it in a plastic bag... it'll sweat". While that's true, one can combat the unwanted sweating with use of a dessicant (don't put the dessicant directly against the metal - it'll corrode). I've heard (but never tried it) that kitty litter will work.
And don't forget: ALWAYS store the uninstalled crank on end - never lay it flat! That'll help prevent warpage.
Old Sep 19, 2002 | 02:30 PM
The Dude's Avatar
The Dude
Default Re: crank storage (Desertvette)
Bob
Day-ummmmmm. That's about the ultimate.
Old Sep 22, 2002 | 10:14 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: crank storage (The Dude)
Bob
and one heavy sumbiatch. :crazy: :lol:
To crank storage
