LPE 219 cam specs please?
Old Sep 30, 2002 | 04:52 PM
Caboboy's Avatar
Caboboy
Default Re: (gkull)
George, are you still liking the Hot LT4 cam with the exhaust system updates?
Old Oct 3, 2002 | 06:59 PM
JAKE's Avatar
JAKE
Default Re: (gkull)
Scorp - The .050 numbers are how it is installed with the 4 degrees ground in. I think it was Beach Bum who installed it straight up (retarded the cam 4*) to gain some top end.
Yep, the ZZ9 has four degrees of advance ground into them too.
All the Tech Section articles I've read on the ZZ9 say to install it 1 to 1.5 degrees retarded to get the best performance out of it that would put it in at 113 to 113.5 using the Lobe Centerline method since it has a 112 LSA/LDA.
Jake
[Modified by JAKE, 3:19 PM 10/6/2002]
Old Oct 6, 2002 | 05:23 PM
JAKE's Avatar
JAKE
Default Re: LPE 219 cam specs please? (VetteRacer282)
[SNIP]As a side note... I am going to be spending $1100 or so on computer/harnss alone... and yes itll be my daily driver.. But then I like spending money :p: [SNIP]
Matt[SNIP]
I did too til I ran out.
Jake
Old Oct 12, 2002 | 09:59 AM
7xchampcar3's Avatar
7xchampcar3
Default Re: LPE 219 cam specs please? (gkull)
Correct me if i'm wrong but doesn't the 219 have a 110* intake center line? I lost my cam card :(
