Need DD2000 bench tested...
Old Oct 19, 2002 | 11:11 AM
BB wowbagger's Avatar
BB wowbagger
Default Need DD2000 bench tested...
Could someone "testdrive" this engine..
454 .030 over bore
10.5:1 hyperpistons
Edelbrock RPM dualplane intake
781 cast heads
2.19/1.88 valves
Cam data/ Solid Rollercam
DUR:278/296
050 DUR:222/234
LIFT:.576/.571
Lobe center:110
Carb: Holley DP 850
Exhaust 2 1/8 headers open
Any comments on the setup? :cheers:
[Modified by BB wowbagger, 4:13 PM 10/19/2002]
Old Oct 19, 2002 | 12:49 PM
MoMo's Avatar
MoMo
Default Re: Need DD2000 bench tested... (BB wowbagger)
529 lb-ft @ 4500 peak, going over 500 lb-ft at about 2400 rpm.
523 hp @ 6000 rpm. Horsepower starts nosing over at 6500. (About where you'd experience valve float).
Very strong engine. I assumed a 750 carb and pocket ported oval port heads. Through mufflers, you don't drop that much either:
515 lb-ft @ 4500, 495 hp @ 5500. So you pick up some top end by uncorking it.
This is a really stout street engine that has some weekend talent at the dragstrip!
Old Oct 19, 2002 | 01:16 PM
BB wowbagger
Default Re: Need DD2000 bench tested... (MoMo)
Yeah,thats what i was hoping for...A "tourqer"...My rev limititer kicks in at 6k so that cam is really what i was hoping for..
The cam says that its good between 1200-6000..,this summer is going to be a blast.
My M20 could be in serious trouble thou,with that tourqe in the lower Rpms.
What do you think? :cheers:
Old Oct 19, 2002 | 10:16 PM
MoMo's Avatar
MoMo
I think your tranny will be okay. The early big block C3's used the M20 and M21 Muncies as well. Just the top power big blocks got the M22's I think, and maybe then only when the option box was checked. Don't know for sure, that's just a guess.
Just watch the dumping of the clutch. If you do too many violent launches and make a habit of it, or speed shift, then you could find the Muncie's weakness.
The bad thing about the aluminum case Muncies was the lack of stiffness in the housing, allowing the helical gears to be pushed out under great torque. (Out as in along the direction of the shaft). This could cause gear damage. The M22 had almost a straight cut to the gears, greatly decreasing end loading.
So if it's a sound Muncie, and you drive it somewhat logically, it'll probably live about as well as anything.
To Need DD2000 bench tested...
