1979 Corvette L82 engine
Old Sep 3, 2019 | 01:35 PM
davidhogue17's Avatar
davidhogue17
1st Gear
Default 1979 Corvette L82 engine
1979 Corvette L82 engine with headers doesn’t like to turn over when engine is hot. Cooled engine turns over and cranks. I’ve replaced starter and battery...any suggestions.
Old Sep 7, 2019 | 01:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
summit sells some heat wrap w.clamps works great.
Or get a mini starter thats clockable...you can even have the solenoid upside down no more problems.
They sell the metal heat shields not sure I like em but they do the trick.
Old Dec 29, 2019 | 11:44 PM
l8279vette's Avatar
l8279vette
Check battery cables. If they say copper clad aluminum get new cables . original cables were copper clad aluminum .
Old Jan 1, 2020 | 02:05 PM
68post's Avatar
68post
..and check your grounds. They are needed ; block to frame, block to battery, frame to battery,...etc...
Old Feb 6, 2020 | 07:35 PM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
How about your timing? What's it set at? If it's too far advanced you'll have the exact problem you are experiencing. Run until it's hot and doesn't want to crank and rotate your distributor a bit and see if that cures it. Good luck 👍
To 1979 Corvette L82 engine
