solid/hydraulic lifters
Old Dec 11, 2002 | 06:26 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default solid/hydraulic lifters
what are the pros/cons of solid and hydraulic lifters.
Old Dec 12, 2002 | 08:00 AM
DeenHylton's Avatar
DeenHylton
Default Re: solid/hydraulic lifters (Guru_4_hire)
Hydraulics are great up to about 6200 RPM (maybe 6500 when the springs are new). Solids will go to 8000 RPM when set up properly.
Hydraulics are none or minimum maintenance (great for the street), solids need to have the valve lash checked at least once a year, more often as your RPM's exceed 7000 RPM.
Solids are more repeatable for ET when drag racing, hydraulics rely on oil pressure to operate...your ET will vary a couple of hundreths of a second depending on oil temperature/pressure. A lot of races are won or lost by .001 or .0001 of a second!
Old Dec 12, 2002 | 01:18 PM
racerns's Avatar
racerns
In addition for a street application solids can have oiling issues if kept a idle for a long period of time. Also Comp now has their "R" hydraulic lifter that is good to higher rpm's not sure how high though. I run them up to 6700rpm with no problem.
Old Dec 12, 2002 | 06:12 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: solid/hydraulic lifters (racerns)
So a good set of hydraulics can reach 6500 rpm? solids are OK for the street just dont get caught in a traffic jam
Old Dec 14, 2002 | 11:17 AM
Smitty's75's Avatar
Smitty's75
I don't really understand the issue about the solid and using it on the street, a lot of the earlier muscle cars of the 60's & 70's used them with out any problems, I had em and had no problems. Remember, the LT1 uses one and I don't see a lot of complaints from the drivers at parades, also I don't think GM would install one in a car that couldn't see "traffic problems", just keep the lifts a little lower, the duration a little higher, and the LSA above 110.
Old Dec 14, 2002 | 11:03 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: solid/hydraulic lifters (autoxer)
I think the oiling problems with solids only pertains to solid rollers, not flat tappets like Chevy and others used years ago.
Old Dec 15, 2002 | 02:28 PM
71coupe's Avatar
71coupe
You can run a bigger mech cam and have better idle than the same size hyd cam. My old solid cam had 234 deg @ .050 & 108 deg lobe seperation. It idled better than my current Comp Cams XE268, which is 224 deg & 110 ls.
To solid/hydraulic lifters
