Help building 350
Old Jan 11, 2003 | 05:15 PM
seansod's Avatar
seansod
Default Help building 350
I am in the process of making the decision on what to build. I have access to a virgin 4 bolt main 350 block that I am going to build to put in my 74 the engine in it now is orginial. I autocross the car and am looking for more ponies.
Info
The car is a convertible 4 speed manual. All parts are stock.
I am going to rebuild the Power steering control valve (leaks) and repalce brake pads and install steel braided lines. I am also installing the VB&P grand touring plus suspension kit.
Do you guys have any idea as to what to build the 350 with.
I plan on boring over 30 and need it to still be streetable and have enough vac.
I was thinking about the Performer RPM Alum heads 70cc ( have a good price on a new set $700)
As I said this will be for autocrossing and the occasional date night with the wife.
Thanks for any help
Tony
I have DD2000 so I will be able to compare any setups you guys suggest.
Old Jan 12, 2003 | 01:06 AM
OatBoy's Avatar
OatBoy
Default Re: Help building 350 (seansod)
hmmm, autocross you say? you probabely want a more radical cam then, u cant really go wrong calling comp cams and asking what cam they'd recommend. if you're using RPM heads you might as well use the RPM air gap intake as well
Old Jan 12, 2003 | 01:42 PM
69stingray's Avatar
69stingray
Where does you engine spend most of it's time during racing? Better yet, went you come out of a corner and want to step on it, what RPM is the engine at? You have many different options. Sounds like fun!
Old Jan 12, 2003 | 06:10 PM
seansod's Avatar
seansod
Default Re: Help building 350 (69stingray)
Just got back form autocrossing today (boy was it cold) and looked at the Tach it appears that when leaving a corner I am at around 3500 RPM.
Old Jan 12, 2003 | 06:56 PM
69stingray's Avatar
69stingray
My first thought was 383 so you can still have some torque for driving on the street, but a 355 w/ 6" Rods will give you a better Rod/Stroke ratio.
I would suggest AFR 210 Heads. They should breath enough to get you the HP you need on the track but still be street worthly (I think).
For cam, I would see what Comp Cam 288HR looks like. I think it is as radical as you can go.
The intake is a toss up, I think overall you will like the Victor Jr. better on the track. Also, a 10:1 compression ratio. If you want to add a fuel additive, maybe a 11:1. Start with 1-3/4" headers.
Try this combo in Dyno2000:
355 w. 6" Rod
AFR 210 Heads
Flow Numbers:
0.2 Lift = 135/112 Intake/Exhaust
0.3 Lift = 197/145
0.4 Lift = 245/185
0.5 Lift = 273/205
0.55 Lift = 277/210
0.6 Lift = 282/215
Comp Cams 288HR Cam Specs: http://www.compcams.com/information/...umber=12-433-8
Gross Lift: 0.52 Intake 0.54 Exhaust
Duration @ 0.006 = 288/294
Valve Timing @ 0.006:
Intake 38 open 70 close
Exhaust 81 Open 30 close
106 Intake centerline
110 Lobe Seperation
Victor Jr. Single Plane Intake
850 Holley
[Modified by 69stingray, 7:02 PM 1/12/2003]
Old Jan 13, 2003 | 02:33 PM
seansod's Avatar
seansod
Thanks I will try that combo and post the results
Tony
To Help building 350
