Carb question
Old Jan 12, 2004 | 03:29 PM
hubes's Avatar
hubes
Default Carb question
what is the difference between square bore carbs and spread bore carbs? is it just the bolt pattern for mounting, or is there more to it? thanks
Old Jan 12, 2004 | 06:20 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Carb question (hubes)
Besides the different bolt patterns between these two distinctions, the square bore carb has secondary throttle bores somewhat similar to the primary bores. The spread bore carb has grossly larger secondaries than the small primaries of this type of carb, hence the name. Besides the bolt pattern, a spread bore carb's huge secondaries won't fit a 4 hole square bore manifold, due to the lack of clearence for the large throttle plates in the rear. Spread bore carbs are made by Rochester, Carter (Edlebrock) and Holley. More specific differences, vary by brand. Good luck, and...
RACE ON!!!
Old Jan 13, 2004 | 09:41 PM
Lionsden's Avatar
Lionsden
This goes along with CFI-EFIs post
[Modified by Dan Plett, 6:54 AM 1/14/2004]
To Carb question
