thoughts on buildup
Old Aug 19, 2004 | 09:39 PM
OatBoy's Avatar
OatBoy
Default thoughts on buildup
i'm puttin together a 350 for use in a little datsun 240, so torque isn't a huge consideration (i think it weights 2800 pounds). what do you guys think of this idea?
CompC. Magnum 12-705-8 mechanical roller with 300/300, 255 at .050
lsa 110 i think
afr 195's.
victer jr. manifold.
this is sort of a rough sketch but ideas are welcome/
OatBoy
Old Aug 20, 2004 | 11:00 AM
comp's Avatar
comp
does the cam match the heads flow?????
Old Aug 20, 2004 | 01:22 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
C'mon now there's bigger cams than that
Seriously you have to match components to make power. That cam along with race ready AFR 210's and 400 or more cubes with at least 1 3/4 in. exhaust would be a good setup.
Old Aug 20, 2004 | 03:39 PM
SteveG75's Avatar
SteveG75
That cam would work well with a 400. For a 350 street motor even with no concern about torque, I would go no bigger than 230 @.050.
However, I have always gone with the philosphy of "one size smaller" than you think you need. After all, how much are you going to drive above 4000 rpm? I coluld have gone 222/230 @.050 on mine but instead dropped to 214/222 and it runs like a beast.
Also, BTW after gkull's experience with Comp and mine, I would definitely go with a different manufacturer. Just my $.02 .
Old Aug 20, 2004 | 06:06 PM
OatBoy's Avatar
OatBoy
okay, so maybe i should do a smaller cam, thats too bad i was looking foward to that idle
the thing is the car is so light that i was purposely thinking of killing torque if possible to keep it from going all over the place, maybe i could run taller gears instead.
do you think a mechanical roller is a good choice for this scenario?
To thoughts on buildup
