Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
block info required.
Old May 4, 2004 | 01:18 PM
WESCH's Avatar
WESCH
Default block info required.
Hi
I found a block for my 68 with following details :
321 4 bolt block with T1120ID stamped, no vin. The cast date I believe is an I7 but the cast date is fairly unreadable.
My car's build date is C 05 = Oct 05 , 1967
I can't work out the stamped suffix number on this block. No ID in my black book for 68.
Also if the block has a casting date of I...7 , being Sept 67 , shouldn't the suffix stamp be something like T09...I. ?
Why is there no VIN stamp on the pad ?
Sorry for all those questions.
Gunther
Old May 4, 2004 | 03:43 PM
JohnZ's Avatar
JohnZ
Default Re: block info required. (WESCH)
The "ID" suffix was used for the 427/425hp engine in '66-'68 full-size passenger cars. Pretty unusual for a block to sit around at Tonawanda for two months before being machined/assembled. If there's no VIN derivative on the pad, it's either a service engine or it's been decked and re-stamped; does the pad show longitudinal broach marks?
Old May 5, 2004 | 02:35 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: block info required. (JohnZ)
If you do get enough numbers together, here is a great site to find out what you have.
http://www.nastyz28.com/sbchevy/sblock.html
Old May 5, 2004 | 11:32 AM
WESCH's Avatar
WESCH
Default Re: block info required. (Desertdawg)
Hi
Nice site, but unfortunately only for small blocks.
Gunther
Old May 6, 2004 | 03:04 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
OOOPS !!!
I will look around and see if I can find a BB site.
Old May 6, 2004 | 03:10 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
OK, try this link.
http://www.mortec.com/bbc.htm
Hope this one helps.
Old May 6, 2004 | 10:16 AM
WESCH's Avatar
WESCH
Hi
Thanks.
Ups, I learned something here, this block was 2 or 4 bolt.
3916321....427.......68......2 or 4 bolt
I thought that it was always a 4 bolt main.
Something else to watch.
Gunther
Old Jun 18, 2004 | 02:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My Chevrolet V-8 Engine Code Pocket Guide shows:
T -- Tonawanda (NY) plant code
11 -- Month of production (November)
20 -- Day of month (20th)
ID -- Engine Suffix generic for 66-68 427
I'd say your have a GM replacement big block.
To block info required.
