Help Forum How To | General Corvetteforum Questions | Feedback
Problem with sig.
Old Aug 14, 2008 | 11:50 PM
Snakecharmer383's Avatar
Snakecharmer383
Default Problem with sig.
I will attach my sig. at the end but my question is...
1. I can't attach a LPE logo as I have seen on others sig's. I have tried but it won't let me.
2. Looking at my sig. is this the largest it can be..I have even deleted some facts about my car in order for it to fit. Is there a limit on the size?
Thanks in advance.
Old Aug 14, 2008 | 11:57 PM
Snakecharmer383
I get this when trying to enter the code for the LPE banner.
"Your signature cannot be longer than 500 characters excluding BB code markup."
Old Aug 15, 2008 | 06:46 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
You may need to work backwards...start with your pic, then add text.
Old Aug 16, 2008 | 03:58 AM
Snakecharmer383
Ok, tried that and didn't work.
I PUT THE BANNER HERE THEN WHATS BELOW
1989 LPE 383
Fully ported alum. heads,stainless steel 2.00/1.56 severe duty valves,tpi valve springs, titanium retainer,forged speed pro pistons, 10.5:1 callies steel crank, 6.75" Dia. harmonic balancer,Hyd roller block,Superram plenum runner kit,Superram base,58mm throttle body,Hyd roller Tpi camshaft 219/219@50, 1.6 ratio stainless steel roller rocker arms,plasma moly speed pro rings,Hyd roller lifters,Hurst Line Loc
Best run: 11.85@119.65mph
http://temp.corvetteforum.net/c4/snakecharmer
and it still didn't work.
Old Aug 16, 2008 | 05:53 AM
MrWhan's Avatar
MrWhan
You should have been able to put what you want in your previous post so I can see what you are trying to do. Go ahead and put your banner in so I know what you want your sig to look like.
Old Aug 16, 2008 | 11:41 PM
Snakecharmer383
1989 LPE 383
Fully ported alum. heads,stainless steel 2.00/1.56 severe duty valves,tpi valve springs, titanium retainer,forged speed pro pistons, 10.5:1 callies steel crank, 6.75" Dia. harmonic balancer,Hyd roller block,Superram plenum runner kit,Superram base,58mm throttle body,Hyd roller Tpi camshaft 219/219@50, 1.6 ratio stainless steel roller rocker arms,plasma moly speed pro rings,Hyd roller lifters,Hurst Line Loc,LPE 1 5/8 stainless steel headers, Forced Air Induction,MSD 6AL
Best 60' 1.70
Old Aug 17, 2008 | 07:44 AM
MrWhan's Avatar
MrWhan
Old Aug 20, 2008 | 11:26 PM
Snakecharmer383
Thanks! I love it!
Why your reading this, I'm having problems embedding video in my threads..could it be something with my settings? I'm copy and pasting the code as it says..I click on the button to "insert link" then paste code in there.
P.S. How did you fix the sig. so I know for future changes?
Old Aug 21, 2008 | 06:38 AM
MrWhan's Avatar
MrWhan
Thanks! I love it!
The only video's you can "imbed" are youtube videos. They have a special set of tags for this [yt] and [/yt]
Otherwise, you should be able to post any link to a video that allows the linking. There is a thread in the TESTING Section that has some youtube assistance (if search works there).
I just edited your signature and put the image in. I don't know if I could do it being a moderator and go over the 500 char limit or if it was because I was doing it from the moderator control panel.
To Problem with sig.
