Help Forum How To | General Corvetteforum Questions | Feedback
Lost data-Message reply
Old Jan 11, 2010 | 07:39 PM
JoeC427's Avatar
JoeC427
Default Lost data-Message reply
Hello,
I think there called "smiles".
When I reply to a post the icons are missing. I did a search and tried to
just reset the cookies, but it did not fix the issue.
Any support would be appreciated.
Thanks,
Joe
Old Jan 11, 2010 | 07:48 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
are you seeing a Red X or nothing at all??
Old Jan 12, 2010 | 12:03 AM
Vette_DD's Avatar
Vette_DD
Here's a response to someone else who had a similar problem. Click the link for more information if it sounds like what's happening to you.
In order for the Smilies to work, you need to have JavaScript enabled in your browser. If it is disabled, the Smilies will load in the Smilies section, but you will be unable to click on them to insert them.
http://forums.corvetteforum.com/1571529063-post2.html
Old Jan 12, 2010 | 09:49 PM
JoeC427's Avatar
JoeC427
Hello,
I'm getting nothing???
They just vanished.
Thx
Old Jan 12, 2010 | 10:05 PM
J T's Avatar
J T
IB Staff
If Javascript was disabled, the Smilies still should display in the panel, they just won't be clickable to insert into the message field.
If you're missing the Smilies, you may have a security software that is blocking the content or mostly the domain. The smilies are served from http://images.ibsrv.net/
Do you see the "Smilies" text listed to the right side of the message when composing a reply?
If you don't see the "Smilies" text listed to the right side of the message when composing a reply, and just see a message box, then go to:
1) UserCP
2) Click on Edit Options
3) Scroll down to the bottom and under Message Editor Interface, you will need to use Standard Editor or Enhanced Interface. The Basic Editor will omit the Smilies control panel and give you just a message box.
Old Jan 12, 2010 | 10:15 PM
JoeC427's Avatar
JoeC427
1) UserCP
JT,
Thanks for the help!
U fixed it.
Joe
To Lost data-Message reply
