When first entering the forums, to the left of the page there is a column that says "Community" when I first started on this site that "Community" used to list all of the C6 forums. I could from there either select General Forum or C6 WTB/WTS Parts. Now when I sign on, it has "Community" and all of the C7 forums. Any way I can get it back to reading "Community" and listing below it the C6 forums? I could really care less about accessing C7 forums.
The default was C6 but since the C7 introduction and the C7 theme was added, now the default is C7. Members can override the default through the above mentioned procedure (which saves to your account) or by using the drop-down menu in the upper right or lower left corner (which is cookie/browser-based).
