c4 sputtering
Old Jul 21, 2011 | 07:52 PM
marcwb's Avatar
marcwb
Default c4 sputtering
I bought a c4 10/0/2010. Replaced opti, icm, coil, plugs, wires and even maf sensor. Starting after full install had code for faulty brand new icm. Replaced, and car ran nice and strong. Since full ignition replacement, I had to replace the icm 2 more times. Every three months the icm has gone bad so went with gm icm. Now 7/20/2011 I am having the same sputtering issues but this time I finally formally checked the icm, and using All Data flow chart-no codes were present- the module from gm checked ok. I also had it checked at Advance Auto. Wires are seperate from engine contract, through logic probe tested consistent pulse from opti-low res and high res signal to ecm, pulse from ecm to module, and pulse from icm to coil. All consistent when engine sputtered under (hot sputtering) condition. I checked fuel pressure also under hot condition, fuel pressure 35 to 45 under load, 45 to 40 koeo. need help to fig out problem.
Old Jul 21, 2011 | 08:15 PM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!! Sorry to hear you're having problems. I suggest you post your situation in the C4 Forum where I'm sure the owners will be able to help. Good luck, enjoy the Forums.
http://forums.corvetteforum.com/c4-tech-performance-48/
Old Jul 21, 2011 | 08:32 PM
guappy's Avatar
guappy
Welcome to the forum
Old Jul 21, 2011 | 09:58 PM
gilhuly's Avatar
gilhuly
welcome to the forum!
Old Jul 21, 2011 | 10:07 PM
jsls0130's Avatar
jsls0130
Hello and Welcome to the Corvette Forum.
Old Jul 21, 2011 | 11:59 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Jul 22, 2011 | 06:32 AM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
Old Jul 22, 2011 | 06:46 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck with the problem!
Old Jul 22, 2011 | 06:29 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum and I know those guys in C4 can help you get through this problem. Good luck
Old Jul 23, 2011 | 03:14 PM
csexton's Avatar
csexton
Welcome
Chuck
Old Jul 23, 2011 | 08:10 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome aboard!
Old Aug 8, 2011 | 12:22 AM
traindude's Avatar
traindude
Welcome aboard and Congrats!
Old Aug 8, 2011 | 07:34 AM
wkidvette's Avatar
wkidvette
Welcome to the forum!
Old Aug 13, 2011 | 06:15 PM
K.Shupe's Avatar
K.Shupe
St. Jude Contributor
To c4 sputtering
