Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Advice - fluid changes?
Old Feb 9, 2012 | 02:00 PM
CA C6 Fan's Avatar
CA C6 Fan
Default Advice - fluid changes?
I have an '07 PT Cruiser convertible (my dd). It has just over 70K miles on the odometer. It has been a very faithful vehicle because I do scheduled maintenance. But I ran into a situation the other day, while having an oil change/tire rotation done at a local GY.
The Mgr. comes up to me and says my car is in "great shape" but asks me when/if the brake/power steering fluids have ever been changed? I said never. He then tells me it is a "manufacturer's requirement" that they be changed every 60K miles. Well, I was a bit dumbfounded because I do read my owners' manual and it says no such thing. So, of course, I took out my manual and confirm with him that he is wrong. So then he says I really should do this maintenance. Still sounds fishy to me. I leave and call my local Mopar dealership and they basically tell me the same thing (not necessary).
Any other mechanics out there that have an opinion on this, it would greatly be appreciated? Do keep in mind, I get that the coolant needs changing (which I'm due soon). Also, because my automatic tranny is a sealed system (Chrysler/Mercedes tranny, I've been told), it does not need to be changed. Thanks, in advance.
Old Feb 10, 2012 | 12:08 AM
Dave68's Avatar
Dave68
Absolutely, the brake and power steering fluid should be changed every so often. I use a turkey baster to remove the power steering fluid (and then add enough to fill) every 5 years or so and then the following year or less. Brake fluid retains water so it should be flushed at every pad change or every 5 years at the most.
Sealed auto tranny fluid? I would never let an auto tranny go more than 30,000 miles (cars older than the mid 2000s) and don't believe in 100,000 changes.
Old Feb 10, 2012 | 10:58 AM
CA C6 Fan's Avatar
CA C6 Fan
Thanks for this info.
According to my owners manual, the auto tranny is sealed (for life), so no changes are necessary. I've checked this out with many mechanics and apparently this is a Mercedes/Chrysler hybrid auto tranny (it works like new, actually).
It's interesting and noteworthy you believe in flushing/changing these fluids. I understand your logic, since both brake & ps fluids would probably attract moisture over time. But I would use the "if it's not broke, don't fix it" logic for both fluid systems, relative to changing. Maybe that is why my owners manual doesn't call for either of these? Fyi, I did replace the pads/rotors at around 50K miles. But I am noticing a bit of soft "whine" in the ps mechanism. If it's going to fail, it would be a bit wasteful to replace the fluid now? Or do you believe if I flush & replace this fluid, it would buy me more time with the present ps mechanism?
Thanks again.
Old Feb 10, 2012 | 11:18 AM
Marlin's Avatar
Marlin
Hahahaaa.. Yea mercedes use to do the lifetime BS till their trans started blowing up under warranty. Now I think its 38k? My E350 has less than 45k on it and it already has problems.
But I agree the trans fluid should at least get a drain and fill every 30k.
Old Feb 10, 2012 | 01:28 PM
jpalamar's Avatar
jpalamar
I do my brake fluid every time I take my wheels off. It only take maybe 5 minutes. Power steering can be a PITA to bleed, but thr turkey baister method is def better then nothing.
Old Feb 10, 2012 | 02:46 PM
CA C6 Fan's Avatar
CA C6 Fan
I can only tell you what the owners manual tells me (and what Chrysler confirms), it is a "sealed system" and no maintenance is required for the automatic tranny.
Truth be told, I have just over 70K miles on this tranny and it works fine (just like it did when it was new). I've heard lots of older Chrysler trannies and most of them make a "rattling" noise when they come to a complete stop, just before they give out. Mine hasn't/doesn't do that.
While I don't doubt the validity of draining/changing other auto tranny fluids, I see no need to do mine. But I do thank you for your comments.
Old Feb 10, 2012 | 02:47 PM
CA C6 Fan's Avatar
CA C6 Fan
I'm curious, what prompted you to change the brake fluid? Please expand? Also, does this mean you do not change your ps fluid?
Thanks for your inputs.
Old Feb 11, 2012 | 06:02 AM
Dave68's Avatar
Dave68
Thanks again.
Many people use the "If it's not broke..." philosophy to justify not changing their oil, air filters and cabin filters, as well as engine coolant with predictable results. I tend to keep my cars for long periods of time (My 89 Mazda MX6 GT has been in my posession for more almost 15 years and my Corvette, more than 10 years) and I have never had power steering, brake, or auto tranny (Mazda) problems, whatsoever.
I once spoke to the manager of an all-German auto shop about the extended oil change intervals BMW, Mercedes and others recommend. He told me that he has had to replace many of their transmissions because the owner would believe the "every 15,000 mile" oil change intervals. The engines, he told me, were full of sludge because the owners didn't drive often or far, producing a breeding ground for sludge.
Sadly, many car owners who sell their cars before any maintenance (lack of) issues arrive, simply trade the car in to a dealership. This is why I buy my used cars from private owners. I can get a good feel for how well the car will hold up just by asking the right questions. If I'm buying an auto tranny car and the owner tells me he or she has never had the coolant, tranny fluid, or brake fluid changed and the car has more than, say, 80,000 miles, I walk away.
Old Feb 12, 2012 | 09:06 AM
68ragtop69's Avatar
68ragtop69
MD Events Coordinator
2015 C3 of Year Finalist
Cruise-In X Veteran
CI-X Car Show Winner
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Thanks again.
There are a lot of car manufactures that have recommended power steering change intervals that are documented in their manuals (most are around 50,000 - 60,000 miles. A good rule of thumb that I follow is to monitor the color of this fluid. As you put miles on your car that fluid will start to discolor from heat generated by the pumps internal components and pick-up contaminants. The soft whine could be signs of your pump starting to go bad or that your current fluid is not lubricating as well as it use to when it was new. I would spend a few bucks now and replace your fluid rather than wait for the noise to get worse or your pump to fail.
I also change my fluid based on age as well. I have a low mileage vette that although I don't put many miles on it, I still change these fluids (power steering, brake and anti-freeze) every couple of years regardless of miles. An ounce ($) of prevention is worth a pound ($$$$) of cure!!!
Old Feb 12, 2012 | 11:40 PM
CA C6 Fan's Avatar
CA C6 Fan
I totally understand about an "ounce/pound". It makes sense to me and that is why I change my oil every 5K miles. And I'm about to change my coolant. But ps and brake fluids changing are new to me. Since my owners manual does not have either as a maintence item, I'm less likely to change them. Although, I do have an issue (soft whine) with my ps mechanism, I will probably change that fluid (along w/your appreciated recommendation) because of this whine. I am hopeful it will mitigate a possible existing condition (ps mechanism faliure). Thanks for your inputs.
Old Feb 26, 2012 | 05:18 PM
Gering's Avatar
Gering
Tolero Apto Victum
I have over 130,000 miles on my 07 Vet and like to change all the fluids & filters every 30,000 miles or every March. Is it needed? No, but I like to do it anyways. I bought the car with 2 miles off the show room and plan on keeping it for many many years.
To Advice - fluid changes?
