Paint/Body Corvette Materials, Techniques, and How To
Dummy needs help on deck replacement
Old Oct 20, 2008 | 12:56 AM
milo30's Avatar
milo30
Default Dummy needs help on deck replacement
I've never worked with fiberglass so everything I'm doing is new to me. I want to do it right the first time so I figured that I would ask in here.
I am replacing the rear deck on my car. I just about have it fitted properly and will be bonding it in place soon. The replacement deck doesn't overlap the bonding strips as well as the original and at the rear there will be a small gap above the bonding strip.
Can someone give me or point me in the direction of a step by step instruction on the proper way to mount this deck? It is on a 78 if it matters
Old Oct 20, 2008 | 09:01 AM
wombvette's Avatar
wombvette
There should be no gaps above the bonding strips. You need to post a picture.
