Paint/Body Corvette Materials, Techniques, and How To
How much Paint
Old Dec 10, 2009 | 11:09 PM
Tony24's Avatar
Tony24
Default How much Paint
Can someone give me an idea of how much paint it takes to paint a C3.
I have a old Binks model 7 I've used before (back in the day), or would I be better off buying a new HVLP gun.
Old Dec 11, 2009 | 08:58 AM
ragtopman's Avatar
ragtopman
St. Jude Donor '10-'11
You have alot of variables to think of, what color of primer did you use, if you use sealer, what color, hi solids vs. no solids color and what color(some hide better than others).
If you use a HVLP, you will use less material. I personally get 3 qts. and that gives me some extra most of the time.
Old Dec 11, 2009 | 06:13 PM
DUB's Avatar
DUB
That pretty much sums it up in a "nutshell".
I can paint then with two quarts (raw)..because my paint system has really good toners...but that is also depending on the color...and if it is loaded with pearls and weak transparent toners. Three quarts would definately work for me and have some for future repairs. BUT it all depends on what paint you buy and how well it covers.
As for the Binks 7. Buy some small amount of the paint that you are going to use and TEST it out and see if you can dial it in and make it work for you. An HVLP would allow you to save more paint and get better paint transfer..than the Binks. So it may be ...buy more paint and not a gun...or a new gun and not so much paint. But regardless which way you go...make sure that you test out what you are wanting to do so you do not have any surprises and not end up with the job that you want. Paint stores should have an "color evaluation card". Which has white and black checkers on it and it allows you to paint on it and see how many coats of base will make the checkers disappear. I do this on all colors that I have not encountrered before, so I know I am getting complete hiding.
"DUB"
Old Dec 11, 2009 | 09:35 PM
markids77's Avatar
markids77
Your model 7 is an old tech Iwata 400... it was the top gun when it was new. If it is clean and does not leak internally, it will still lay down a gloss with the best of them. If you're in tune with the gun, buy a full gallon of paint and spray away. No need for the "latest best" to get a good single paint job for yourself.
To How much Paint
