Paint/Body Corvette Materials, Techniques, and How To
Body panel alignment
Old Apr 29, 2010 | 09:20 PM
guidorr73's Avatar
guidorr73
Cruising
Default Body panel alignment
Hi all,
I just purchased my 1st vette. It is a 1980. I am new to the forum and was hoping to solve probably the 1st of many problems. I am having a problem lining up the hood with the drivers side fender. The gaps are looking really good but the hood sits a half of an inch higher then the fender. It is flush at the hinge and the hood latch but tapers up in the middle. The hood is fine and level. I measured the inner lip of the fender to the top A arm on both sides and the drivers side is a half an inch lower then the passanger side. The passanger side is perfectly flush the whole length of the hood. Can the middle of the drivers side fender be raised a bit and how? Are there any other options. Unfortunately I do not know the history of the car as far as accidents, but it does not look like anything was taken apart.
Thanks for any help, Larry.
Old Apr 29, 2010 | 10:48 PM
wombvette's Avatar
wombvette
Originally Posted by guidorr73
Hi all,
Most unusual, Most of the time it is the other way around. I would suspect some previous damage.
Old Apr 30, 2010 | 06:29 PM
DUB's Avatar
DUB
Is the inner skirt (wheel well) still bonded to the upper fender where the hood is high on that side...or is it loose.
Does the hood have a crack in the under structure where it gets thin right near the hood support area? or on the other side?
"DUB"
Old Apr 30, 2010 | 08:40 PM
guidorr73's Avatar
guidorr73
Cruising
The fender is still attached and solid. No noticeable cracks or flaws in the spot under the hood. Even the hood is very solid. Maybe it was a bad repair job. I just need to rectify the problem.
Old May 1, 2010 | 09:04 AM
DUB's Avatar
DUB
Possible issue is the area where the inner skirt bonds to the inside edge of the rain gutter area ABOVE where your control arm is located needs to be seperated and lifted to flush and re-bonded....BUT without very good photo's ...this is the only answer I can advise you with at this time.
If you hood is flush at the hinge then the area further back will be lifted to correct this issue when the panels are seperated....and then bonded.
"DUB"
To Body panel alignment
