Paint/Body Corvette Materials, Techniques, and How To
Woobly Mirror
Old Sep 4, 2013 | 12:32 AM
croaker's Avatar
croaker
Default Woobly Mirror
Hey Guys need some help.My 75 passenger side mirror is so woobly where it mounts to the door it's embarrasing. I changed well nuts thinking they weren't getting tight enough.It's still bad any ideas ya'll would care to share? I've thought of installing a back up plate from behind,but kinda worried about stress cracks. I've looked around at other cars and they seem super tight.
Old Sep 4, 2013 | 08:26 AM
Scott Marzahl's Avatar
Scott Marzahl
It could be the bracket that screws to the well nuts or mirror itself. I had a sloppy passenger mirror with a new kit and it was a loose fittin bracket, installed new bracket from paragon and fixed it.
Old Sep 4, 2013 | 06:24 PM
DUB's Avatar
DUB
YEP...I know the fix that does away with the well-nuts entirely. Call me and I can tell you how to do this.....and yes it can be done because I have done it numerous times....but it does take a bit of time and PATIENCE.
The procedure will take a bit of time on the phone...and forever to type out...so a call from you might be in your best interest.
704-394-5150 EST M-F 8-5 Sat-Sun 10-4
DUB
Old Sep 4, 2013 | 10:01 PM
croaker's Avatar
croaker
The bracket is suspect. My plan is small flat plate tack on some nuts then tack a heavy wire to bracket for positioning. What type of cushioning should I use between plate and inside of door or am I over thinking this.
Old Sep 4, 2013 | 10:04 PM
croaker's Avatar
croaker
Thanks for the replys guys
Old Sep 5, 2013 | 06:00 PM
DUB's Avatar
DUB
Very close...but do not tack wire to it...and use any cushioning. I have done this numerous times and can fill you in...unless you care to figure out the puzzle yourself. NO CUTTING to the door is required.
DUB
To Woobly Mirror
