Rookie Mistake
Rookie Mistake
Tried to shoot SPI Turbo 2K for a second time last night. This is the second time shooting with a brand new HF Purple gun with the nozzle drilled out a little for the thick primer. the gun worked perfect the first time (see picture) but this time it would only spray for a few seconds and then stop spraying. gun worked the first time so it must be clogged so I restrained the primer and cleaned the gun and it still didn't fix it so I cleaned and restrained again with no luck. I found that when it stopped spraying if I took off the air hose and shook the gun with the trigger pulled it would spray great for a couple of seconds. one time while shaking it (with great frustraion!) I heard a gurgle. I opened the cap and found the air vent clogged!!!! I drilled it out and it works perfect (wow do I feel stupid!!). as usual read directions and know your equipment, most times it is operator error. This is just to help other rookies out there.
BEST thing about this mistake is that it will only happen ONCE!
DUB
DUB
71frameoff (06-02-2016)
