Paint/Body Corvette Materials, Techniques, and How To
Prepping flared quarter panel
Old Mar 12, 2017 | 04:00 PM
RBrid's Avatar
RBrid
Default Prepping flared quarter panel
Greetings. This is for my '77 C3. I am in the process of replacing the rear quarter panels with hand-laid flared ones. Here are two issues I'm facing and the plans I have to address them.
#1. The new panel is thicker than the original one.
Plan:
- grind down the backside portion of the new panel that is glued to the bonding strip, to make it flush with the rear clip.
- after gluing with Evercoat SMC Panel Adhesive, add a layer of that adhesive on top of the bonding strip and new panel to strengthen the grinded area. (see picture)
#2. The new panel does not have the rear 'flange'.
Plan to maximize strength and minimize future ghost line:
- cut off the rear 1" of the old panel, after stripping it to raw fiberglass.
- cut off the rear 1" of the new panel.
- graft the old 1" piece with the flange to the new panel:
- taper the two pieces on the back side, glass them together, VPA them (i.e. the usual stuff)
- taper the two pieces on the front side, glass them, VPA them
Do these sound like good plans?
Bonus question:
I'd like the inner side of the panels to be smooth. Same for the hand laid high rise hood that I got. Because they're hand laid they're not smooth. What material would you apply to make them smooth? VPA maybe?
Thanks!
Old Mar 12, 2017 | 05:26 PM
DUB's Avatar
DUB
Plan:
- after gluing with Evercoat SMC Panel Adhesive, add a layer of that adhesive on top of the bonding strip and new panel to strengthen the ground area.
You are CORRECT in using the SMC panel adhesive to bond your new panel on. AS for filling in the seam...you could use the same SMC panel adhesive but it has to go on thick so it will cure. Personally ..I use the Vette Panel Adhesive in the seams and have never had an issue. That is up to you.
I would either:
1.) Cut the flange off the original quarter and cut more than 1 inch. I would cut at least 2 inches if not more...even if I had to cut it so it could go around the side marker light area. I would prep the panel and bond them in with the SMC panel adhesive. Prepping the aftermarket quarter can be a bit tricky in order to get the flange to fit best as possible...AND YET...making sure the integrity of the flange is still strong and has not been weakened by excessive grinding.
2.) I would mask off the new quarter and laminate in mat and resin and make my own new flange.
Bonus question:
Thanks!
YES...carefully sanding and prepping the backside can be done because I have done that on hand laid hoods also. Keep in mind that when I do it. I do not want to see ANY shine.reflection showing up on the fiberglass that has not been ground on. It must be 100% dull before I apply the VPA. I had an easy 40 hours on the backside/underside of a short 1969 L88 aftermarket hood to get rid of all the hand laid fiberglass look. I am glad I did it because now...it can be cleaned easily with a paper towel.
DUB
Old Mar 12, 2017 | 07:34 PM
RBrid's Avatar
RBrid
Thanks for the input DUB!
Regarding the seams: Yes, I'll use VPA for sure. It's the purple part in my original picture.
Regarding the flange: I'm leaning toward option 2 then. I suppose you mean something like the picture below.
Regarding smoothing things out: great. That's what I had in mind. I want it to look good and to be cleanable easily.
Old Mar 13, 2017 | 06:04 PM
DUB's Avatar
DUB
YES. Also...not 'saying' that you would not do so...BUT...keep in mind how you laminate this to create the flange. That 90 degree bend is going to be a bit of fun to get laid correctly. So...take your time and possibly 'filet' your mat to make it less 'starchy' so it can easily bend. Kinda like how you can easily bend veneer...but not a 1/2" thick piece of plywood. But you could stack up numerous sheets of veneer and make it be 1/2" thick and bent or curved when done....if that makes sense.
DUB
Old Mar 13, 2017 | 11:30 PM
RBrid's Avatar
RBrid
OK - thanks DUB. I know what you mean. I'll post pictures when I'm done.
Old Apr 29, 2017 | 06:24 PM
RBrid's Avatar
RBrid
Default The work
Alright, here we are many weeks later, and the flanges are finally done. Here are some pictures of the process I went through. I'll make a second post with pictures of the results.
Old Apr 29, 2017 | 06:33 PM
RBrid's Avatar
RBrid
Default The result
The final flanges look strong to me. I added VPA on the interior sides to make them flat and add strength. They ended up being about 1/4" to 5/16" thick. Looks good?
Some VPA will be added on the exterior sides to make them flush with the rear bumper flange, after the quarter panels have been glued in place. Gluing them in place is my next step, with SMC Panel Adhesive.
Thanks.
Old Apr 29, 2017 | 10:20 PM
DUB's Avatar
DUB
ABSOLUTELY NOT ONE PROBLEM I can see in what you did. QUITE AWESOME work.
And YES...I feel that your new flanges are NEVER going to fail you due to their construction!
SUPERB!!!!!!!
DUB
Old Apr 30, 2017 | 02:57 PM
RBrid's Avatar
RBrid
SUPERB!!!!!!!
DUB
Thanks DUB - I appreciate it! I added one layer of glass daily over a period of two weeks.
On to the next challenge...
Old Apr 30, 2017 | 06:55 PM
DUB's Avatar
DUB
Job well done!!!...but ...you do know that you can apply more than just one layer at a time once you get a solid foundation to apply pressure on.
I know that you can do what you are comfortable with....I am just saying that going up to 3 layers is about as far as I take it due to the heat being built up while it is curing. May save a tab bit if time.
You still did a remarkable job !!!
DUB
To Prepping flared quarter panel
