Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
line locks
Old Mar 19, 2005 | 10:10 AM
Yellow03ZO6's Avatar
Yellow03ZO6
Default line locks
I have a question for those of you who have line locks on your ZO6. Do you have any trouble with your ABS light coming on when you use your line locks, or have any issues with it? How many different types of line locks are available and which one is the better one to get? any info would be great. thanks
Old Mar 19, 2005 | 11:30 AM
algZO6's Avatar
algZO6
Abs light does com on for a few seconds but then every thing is ok. cartek is the way to go if you are in the market. good luck.
Old Mar 19, 2005 | 11:42 AM
mdhmi's Avatar
mdhmi
My Hurst works great. Heck of a deal for $110.
Mark
Old Mar 19, 2005 | 02:56 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I'm running a TCI unit. No lights come on at all.
Bob
Old Mar 20, 2005 | 10:58 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Are they easy to install? I want to put one on mine.
Old Mar 20, 2005 | 11:07 PM
Yellow03ZO6
Mark
did you order yours online or local performance shop?
Old Mar 21, 2005 | 09:33 AM
algZO6's Avatar
algZO6
carteks unit is very easy to install. i pulled the alternator to do it but you don't have to it just makes it alot easier.
Old Mar 21, 2005 | 11:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Especially with the Cartek kit!
Old Mar 21, 2005 | 11:41 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
The Cartek kit is easy to install and IMO the best bet as everything is already bent to the correct angle, flaring, flanges and bolts are already done and to the correct length. Cost a bit more but well worth it.
Old Mar 22, 2005 | 04:28 PM
mdhmi's Avatar
mdhmi
Local performance shop. I asked them to match an online price and they agreed.
Mark
Old Mar 22, 2005 | 05:52 PM
Yellow03ZO6
Mark
i purchased the hurst line lock set up, were did you hook yours up to. did you go right to the master cylinder or did you hook it to the abs?
Old Mar 22, 2005 | 11:51 PM
Yellow03ZO6
i was reading the instructions on the hurst line lock and it says it is not recomended for cars with abs
Old Mar 23, 2005 | 02:01 PM
16Again's Avatar
16Again
They all say that. It is fine, no problem using it.
Old Mar 23, 2005 | 02:36 PM
C5 CU's Avatar
C5 CU
RPM (Lewisville TX) installed my line-lock and put the switch under the shifter boot on back plate...can't see a thing...just take hand from shifter straight down and hold button etc etc....really clean and totally out of sight.
Old Mar 23, 2005 | 02:51 PM
Yellow03ZO6
thanks for the info i just wanted to double check, im having it installed tomorrow morning
Old Mar 23, 2005 | 08:20 PM
16Again's Avatar
16Again
Anytime As you can see by the above posts, I think we have all the manufacturers accounted for. Enjoy the new burnout ability
Old Mar 23, 2005 | 10:09 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
BURNOUT CHAMP @ CARLSBAD 2003!
To line locks
Old Mar 24, 2005 | 11:11 AM
Yellow03ZO6
line lock installed , no problems, i love it
Old Mar 24, 2005 | 01:21 PM
KapUSMC's Avatar
KapUSMC
I think this is goin to be my next mod... Probably should have done it a while ago...
Old Mar 27, 2005 | 12:36 AM
dads01dream's Avatar
dads01dream
Anymore have some instructions for installing the Hurst unit on a C5?? I put one in YEARS ago on my old '89 Stang.... pretty easy/straight forward, sure would be nice if the same could be said of a Vette install.
