Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Lpe 383
Old Aug 17, 2005 | 11:21 AM
  #41
C5XTASY's Avatar
C5XTASY
Originally Posted by baitbuster
I have a yank 2400 with 3.42s and it feels great. Just like stock, my car idle's at 700. When you take your foot off the brake at a light, it moves forward like stock. If you have a bigger cam you might want to go to a 2600-2800. Call LPE, they can help you out.
Lee
Lee, I have the Comp Cam XR269HR, 216-220 cam you mentioned that you had in a previous engine, in an earlier post. I really like it. My numbers are 376 rwhp and 375 rwtorque, SAE corrected and smoothed. I really love how the car performs. Did you have a higher stall converter, and deeper gears, when you were running the 216-220 Comp Cam?
Ed
Old Aug 17, 2005 | 10:27 PM
  #42
loudsam's Avatar
loudsam
Originally Posted by C5XTASY
Doug, I'm about 180 miles away. I also had ridden in a Z28 with a 3500 converter, and didn't like it. Way too loose for my taste. The 3.42s, and Protorque 2400-2600, in a 2001 C5 with similar power, seemed perfect to me. Under normal driving, the combination felt very tight, like stock, until it was jumped on, then...BAM! His cam was larger than mine, but peak power was very similar. I probably have a stronger low end than that car did. Can't wait!
Ed
Your only about an hour away, If I REALLY stepped on it! When I'm off on vacation again, in September, I'll PM ya! By then you may have your new set-up in.
Old Aug 17, 2005 | 10:54 PM
  #43
baitbuster's Avatar
baitbuster
Ed
Ed, my numbers were 374/375 through stock exhaust and TC/ 3.15 gears. I was running 12.1 CR, idle was 750rpms. The car ran great but would creep at the light with the stock TC. Great street car from light to light, alot of torque. One of those cams that they call baby cam. On the dyno my car was still pulling at 6500 rpms.
Lee
Old Aug 17, 2005 | 11:45 PM
  #44
C5XTASY's Avatar
C5XTASY
Lee
That cam really fills it in "under the curve". I really like it. And you're right, at 6500 rpm it's still reaching....great street cam!
Ed
Old Aug 18, 2005 | 01:36 PM
  #45
C5XTASY's Avatar
C5XTASY
Doug, let me know. I'll see if there's something I can do with my schedule. However, I will not be having the converter and gears installed until early winter, following which I was planning on storing the car until next spring. That way I don't lose driving time. Take care and stay in touch. I'd like to get together, too!
Ed
