Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
halltech stinger
Old Aug 29, 2005 | 01:44 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Default halltech stinger
Halltech Stinger is on, Super easy install, read
about a few small probelms. But mine went on in three minutes.First night car was rich,Little doggy
second night Little better, 3rd Night after an hour or so each night
She caught on and pulls "very noticeably" harded and quicker.
Woke up the ti- exhaust
Here is a tip for, You stinger owners, I made 2 small 1 inch by inch
rubber blocks and placed them under the front and rear of the
filter, between the radiator panel the stinger filter lays on, and the filter itself.Raising the filter, One inch
This allows 360 degree air around the whole filter.
Loosen the coupler screw, to the halltech bridge,when you do this.
put in the blocks retighen.
This makes the Halltech even better.
Also you want a quarter inch gap between the MAF and the filter.
So the Neck of the MAF is not sticking into the filter. This causes
turblence That was in the instructions
Dyno time coming again that 357. was on a bad day
(weather)
Old Aug 29, 2005 | 01:56 AM
jophis37's Avatar
jophis37
can't wait to see your #'s
Old Aug 29, 2005 | 02:43 AM
3 Z06ZR1's Avatar
3 Z06ZR1
thanks man, and a picture coming, with my new ce stripes
Old Sep 19, 2005 | 03:18 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Was on the dyno to check things out, on 9-16. Which showed 2hp,2-3 tq gain on the first pull,My tuner said the a/f was bad (lean)So
he started making adjustments.
went from stock with K&N w/ziptie mod
357.4rwhp 346.4rwtq on 6-10-05
To stock w/Halltech 9-16-05
stinger
366.9rwhp 357.3 rwtq
So dyno tuning was really needed in my case.
Car runs like rocket!
Gain with tuning with zip tie mod really gained nothing
Gain with tuning with Halltech 10 rwhp 11rwtq
nice gain from an intake
To halltech stinger
