Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Head Games
Old Jan 14, 2007 | 10:47 AM
BERGN8R's Avatar
BERGN8R
Default Head Games
I'm looking to move up to heads and a cam this year. It's great that we have so many choices now. Is there a clear winner as best heads or even more importantly a manufacturer to stay away from? Is there a problem with aftermarket heads on on a '98?
Also, a local engine builder suggested porting my stock heads, any thoughts? My goal is faster 1/4 miles and maintaining relative streetability. I'll look into the cam later.
Old Jan 14, 2007 | 11:41 AM
vettenuts's Avatar
vettenuts
You need to narrow down your cam selection first. I tend to stay with low port volume heads such as the AFR's that increase velocity and the lower end of the curve. Makes for more usable power on the street.
Old Jan 14, 2007 | 01:28 PM
BERGN8R's Avatar
BERGN8R
Thanks. I guess I should have asked which to select first.:o
Old Jan 19, 2007 | 09:38 PM
Blow Torch's Avatar
Blow Torch
As for as heads, I went with the Dart 205s. They are a great bang for the buck
Old Jan 20, 2007 | 08:56 AM
vettenuts's Avatar
vettenuts
Actually, there is a guy on LS1Tech who has a set for sale right now, new in box, at the original Dart price before the price increase. I think they are around $1,300 if you are interested. Handle name is "studytime".
Old Jan 20, 2007 | 05:06 PM
BERGN8R's Avatar
BERGN8R
Do you have any performance or dyno numbers and what cam or other mods do you have?
Old Jan 20, 2007 | 06:40 PM
vettenuts's Avatar
vettenuts
Here's mine. If you do an advanced search in the archives (click at bottom of advanced search page) in the performance section a whole bunch will pop up.
Dart 205's
Old Jan 20, 2007 | 08:15 PM
miami993c297's Avatar
miami993c297
Those one for the results in my sig :
Christian
Old Jan 21, 2007 | 08:43 AM
Blow Torch's Avatar
Blow Torch
You can look at my sig for the mods, but my cam is a smallish 224/571 comp cam. (good durabilty and low end torque)
I picked up approx. 30hp if my memory serves me correctly. I already had the cam and headers, so the only change was the heads, and from a blackwing to a vararam (no effect on a dyno) These changes are on an auto with the TC unlocked! The change proably would have been even greater, but I already had a set of milled (.020) LS1 heads on the car. The low end torque change is KILLER!!
There are a lot of great heads out there that put up some great peak #s, but IMO the Darts are a great head for the cost of admission.
Old Jan 21, 2007 | 07:55 PM
ksett's Avatar
ksett
Top 3 in this order: (this is IMO based on results I've seen)TFS 215, ETP 215 and AFR 205. I wouldn't bother with any other brands if you have the means to buy one of the above.
Old Jan 22, 2007 | 03:41 PM
nickolbag's Avatar
nickolbag
A good set of ported stock heads will do just as good if not better at the track against after market heads provided you have the right people working on them.
Old Jan 25, 2007 | 10:39 PM
HeadGames's Avatar
HeadGames
I totally agree..smaller port volume means alot of tire frying torque and 2 tons of fun..In my opinion if the engine is stock otherwise, then I would do a stock ported head and cam combo
Old Jan 26, 2007 | 12:35 AM
AmMscl's Avatar
AmMscl
Not to mock you, but do you care to explain...I've ran the AFRs and a decent Comp cam and loved the combo in my 02 (430RWHP 400TRQ). Now I'm driving a stock 04 Z06 and considering ported LS6 heads....but would be if they were
Old Jan 26, 2007 | 10:02 AM
nickolbag's Avatar
nickolbag
Dont worry. No offense taken. Any way you get it, who wouldnt love 400+ hp& tq! My point what just that there have been a good amount of records set on ported ls6 heads and a lot of good times produced with them. I'm not knocking the aftermarkets at all. There have been a few combos now around the 500rwhp range with aftermarkets. I dont know what they run at the track though. Me personally, I like to see track numbers as opposed to dyno numbers. Cant manipulate the quarter mile times like you can a dyno.
Just out of curiosity. What did you run in your 02? Your numbers with the AFRs are pretty close to what my car just made with ported 241s. I dont have any numbers yet. Still waiting for the weather to warm up.
Old Jan 26, 2007 | 12:25 PM
BERGN8R's Avatar
BERGN8R
I found an old Hot Rod Magazine where they took a crate LS1 and used port LS6 heads, Comp Cam (don't have details with me right now) and the FAST 90mm setup. They Dyno-ed over 530 hp at the flywheel.
Old Jan 26, 2007 | 01:35 PM
bobbss's Avatar
bobbss
The way I understand it is the after market heads help more in the lower rpm band which makes them better for street driving.
Old Jan 26, 2007 | 09:24 PM
vetred's Avatar
vetred
While your point is well taken,..about "good personal" doing the work,.....HOWEVER,.... I think that almost ALL the aftermarket heads will out flow reworked stock AND there is an awful lot of Information over on the "other" forum, "LS1 Tech" on this subject like the "ABSOLUTE" most comprehensive testing AND posting of those results!! the darts have had a lot that's a "lot" of ,............"concerns" about,......smoking??? Though the latest information is that all has been remedied!!! the A.F.Rs simply cant be beat though a bit near,.....pricey,.... and that leaves the, "ported LS6 heads,.. witch Im buying RIGHT NOW!! Per the advice of one of the best tuners for a thousand miles T.J.Wong!!
To Head Games
Old Jan 26, 2007 | 10:31 PM
AmMscl's Avatar
AmMscl
I ran 12.60s@120 with a 2.10 60':o and had really bad wheel hop...the car actually ran alot harder on the street (it worked (2) 11.90s cars from a dig by a pretty good margin ) A lot guys in the area were jawing about a hidden unit (NOS) in the Z Because it really ran that hard....especially in 3rd
Old Jan 27, 2007 | 05:01 AM
vettenuts's Avatar
vettenuts
Originally Posted by vetred
the darts have had a lot that's a "lot" of ,............"concerns" about,......smoking??? Though the latest information is that all has been remedied!!! T.J.Wong!!
Just want to comment on the Dart smoking issue. The only smoking issue was when a vendor ported them, from what I understand they were overported and the oil was getting in through cracks. I recieved my Dart heads, carefully disassembled them to smooth out the casting flash in the ports and re-assembled adjusting spring heights to within 0.003 overall for both heads. I re-used the Dart seals and the Dart heads use less oil than my stock 241's. It is unfortunate that Dart's reputation was hurt by this as the parts they use are top shelf. The valve springs they use are the same ones that Katech just tested and selected for thier 427 builds. Valves are drop forged and lighter than stock, even though they are a larger valve.
Old Feb 7, 2007 | 03:59 PM
PacWest's Avatar
PacWest
Hi Vetred,
I tried to PM you but it's full.
I live in Issaquah too. I have a white 01 Z06.
I'm looking at H/C options and I noticed your recent post about going with ported LS6 heads and TJ Wong. I have an extra LS6 long block - my original engine. I've been considering pulling the heads and having them ported rather than buying aftermarket heads.
Who is doing your port work? I am leaning towards Cartek at the moment but Texas Speed talks a good game and is cheaper. I just think Cartek has a better package - including intake porting, injector sizing etc.
Is TJ Wong in Oregon? I would like to know your approach to the H/C and what TJ is doing for you.
Let me know when you get a minute.
Thanks,
Ryan
