Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Mods steps???
Old Aug 14, 2008 | 10:13 PM
david1st's Avatar
david1st
Default Mods steps???
HEY GUYS! I'M LOOKING 4 UP-GRADES IN STEPS ON MY 02 C5 VERT (A4).. MY 1ST UP-GRADE WAS A COLD AIR INTAKE (VARARAM). WHAT SHOULD BE NEXT? THANKS!
Old Aug 14, 2008 | 10:45 PM
motogib1's Avatar
motogib1
If you really must continue modification, the next step would be long tube headers with hi-flow catalytic converters and tuning. If you have 2.73 gears, a gear change to 3.42s is also a good modification. Just my .02.
Old Aug 15, 2008 | 12:09 AM
4DRUSH's Avatar
4DRUSH
Don't waste your money on a vararam, etc, etc, etc. Get a ECS Paxton Supercharger and be done with it.
Old Aug 15, 2008 | 05:30 PM
david1st's Avatar
david1st
want more info..... s/c vs. turbo(s)
Old Aug 15, 2008 | 05:55 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
I 2nd the SC, If I could start over, I would get the SC and be done with it.
Old Aug 15, 2008 | 06:30 PM
MikeV's Avatar
MikeV
What are your goals? What I mean by that is do you want a street car? Do you plan on tracking the car, IE drag race or road race. Do you care about milage? Do you care about drivability? How about emissions tests? All these thing have to go into the equation.
Now that being said, if all you want is a fast street car, than the SC is the way to go.
Good Luck
Mike V
Old Aug 15, 2008 | 06:31 PM
david1st's Avatar
david1st
s/c over turbo???
Old Aug 15, 2008 | 08:06 PM
4DRUSH's Avatar
4DRUSH
s/c over turbo???
Both have there Pros & Cons
Most choice a SC which are about 5K cheaper than a turbo set up
ECS Paxton SC installed (turn key) is around 8K
Old Aug 15, 2008 | 10:16 PM
david1st's Avatar
david1st
looking at just a faster street car....what avg. mpg do you get with a s/c ?
Old Aug 16, 2008 | 12:28 AM
4DRUSH's Avatar
4DRUSH
I heard the same if not better staying under 3,000 rpm's. ( I am not capable of that so I don't know for sure) After 3,000 rpm any power adder would need extra fuel to make the extra power
To Mods steps???
