I just did a cam swap to a Whiplash and tune. Other mods are:
LG Streets, Off-road X-pipe No cats, Borla Stingers, RPM Level IV A4 with transgo 2 kit, stock converter, 2.73 gears, Flip-tie air box mod, Sumitomo HTRZ III tires(Summer Max performance rating)
Prior run with only Borla Stingers it ran 8.57 with a 1.99 60'.
Suppose to be 70 degrees and cloudy at the track this weekend.
I'm gonna say low 8's, only because you still have stock converter and gears w/ that big cam...throw in a 3000 stall and 3.73 gears and I'd say mid 7's
Well I got some longer push rods ordered (7.425) and if they come in tomorrow I'll take it to the track Saturday. I got some valve train clatter when it warms up to 171 degrees and then goes away after it gets to 198 degrees and a few taps of the throttle.
I can foot break it to about 1300-1400 RPM on the launch and burn the damn tires off of it on the street (closed course) spinning all the way halfway through 3rd gear.
