Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
List your Dyno Numbers
Old Feb 16, 2010 | 10:22 PM
  #201
06x6spdGTO's Avatar
06x6spdGTO
okay ill try.
460 Rwhp/418 Rwtq on 91 Octane
Forged 347ci LS6, 3.905 bore, Probe LW I-beam Rods, Diamond Pistons, Total Seal Rings, Tsp 233/239 598 603 113 LSA cam, Clevite "H" Mains, Arp Bolts/Studs, Ported 243 heads, 10.8 SCR, PRC .660 Dual Springs, Manly Pushrods, LS7 Lifters, Callaway Honker CAI, SLP Underdrive Pulley, Kooks 1 7/8 LTs, 3 in Catless Xpipe, B&B dual tip Bullets, Centerforce DF 12" Clutch, Hinson Ported Fast 92, Ls2 90mm TB, FOULED MAF sensor!!! Still Tuning
Old Feb 23, 2010 | 01:04 AM
  #202
MDR1970's Avatar
MDR1970
Just got my car back from tuner on Saturday. 2002 Coupe,MN6,3.42 gear,Patriot Stg II heads, 233/239 595.603 112lsa, 25
pulley, Dynatech LT's and cats, LS7 lifters, LS6 intake. Mx power=432.67 Mx Tq=379.30
Old Feb 23, 2010 | 03:13 AM
  #203
TransAm2002's Avatar
TransAm2002
Update on power adder list:
634 RWHP 786 RWTQ
Old Feb 24, 2010 | 10:47 PM
  #204
bcarp's Avatar
bcarp
Default Dyno
Here is one for everyone to disect.
98 6spd
stock bottom end
Stock 243 heads
Whiplash Cam
LS6 intake
Ported Throttle Body
After this I found out I had rocker problems, I think that is why the HP levels off at 5900
Old Feb 25, 2010 | 12:42 AM
  #205
Leukic's Avatar
Leukic
K&N CAI
Headers back Exhaust no mufflers
Stock motor
B&M Shifter
Old Feb 25, 2010 | 11:58 PM
  #206
AZZ-KIKR's Avatar
AZZ-KIKR
02 ZO6
Stock Engine
A&A S/C kit P1 w/ 8.5" pulley ~8.5 psi
Snow performance Meth injection
Lg long tube Headers, High flow cats
GHL Bullets
27* timing on pull.
Old Mar 13, 2010 | 01:52 AM
  #207
c6z06forme10's Avatar
c6z06forme10
395 RWHP/380 RWTQ
02 Z06
LT's, Catted x-pipe, B&B Bullet exhaust
Breathless CAI
LS7 Clutch
Small cam (Unknown size. Was in it when i bought the vette)
Tune still seems to be off a bit...
Old Mar 13, 2010 | 02:00 AM
  #208
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Just finished my FAST 92 and LS2 TB. New numbers coming soon!!
Old Mar 16, 2010 | 12:20 AM
  #209
TransAm2002
Update please:
634 RWHP 786 RWTQ
Old Mar 18, 2010 | 04:30 PM
  #210
The Dibble's Avatar
The Dibble
2002 z06
AR headers with off road X-pipe
borla stinger catback
vararam CAI
FAST 90 intake
Ported LS2 throttle body
Tune
403hp 395 trq
Old Mar 18, 2010 | 06:07 PM
  #211
WKMCD's Avatar
WKMCD
The guys strapped it down on the DynoJet and we've got some first numbers.
It idles at 800RPM smooth as glass which should tell you how small the cam is.
Ed tells me he and Shawn might not be done quite yet.
Not to bad 576/530NA !!!!!
Old Mar 23, 2010 | 07:09 AM
  #212
Quickshift_C5's Avatar
Quickshift_C5
2001 Corvette zO6
360rwhp/364rwtq
LG Pro Longtubes
Cat-Deletes
B&B Bullet Catback
Tune
Old Mar 23, 2010 | 10:21 AM
  #213
Smoove's Avatar
Smoove
00 Fixed Roof Coupe
05 LS6 stock block
AFR 205's untouched
233 237 649 598 -112
FAST 90 unported
Pro Turbo Kit w 67mm precesion turbos.
12 degrees of timing
11.5psi
fuel system maxed out @ 5800rpms(lifted then)
787rwhp
696ft-lbs
Complete new motor and fuel system in works.
Old Mar 25, 2010 | 11:31 AM
  #214
Choose1's Avatar
Choose1
Just Hit the Dyno Last night, will try to post a graph later. Got real bumpy around 5500
98 Vert 6sp
Forged 346
Ported 5.3's
MS3 Cam
LS6 Intake
BBK TB
OBX Headers-No Cats
Ti Catback
414rwhp
384rwtq
Old Apr 4, 2010 | 12:48 AM
  #215
whiteboy572ci's Avatar
whiteboy572ci
2001 Z06 Mods:
-Comp 224/228 .581/.588 114+4
-Comp Pushrods
-Patriot gold duals
-Vararam intake
-Textralia clutch
-LS2 timing chain
-Harris Speed Works (Wet 78mm plate kit, run on the 100 shot)
-CCA catch can
-Racetronix fuel pump
-MicroEdge nitrous controler, Bottle warmer, purge, etc
-LGMotorsports Long tube headers with off road x-pipe
-QTP cutouts (Not open on any of the pulls)
-WCC Smooth bellow
-NGK tr6s (Gapped to .034)
*106,xxx miles on original engine.
392whp/384wtq (NA)
486whp/509wtq (100 shot)
Old Apr 5, 2010 | 01:20 PM
  #216
sublime1996525's Avatar
sublime1996525
02 z06. Stock bottom. 232/234 .595/.598 cam, yella terra 1.65 rockers, trick flow 215 heads 59cc chambers, ported fast90 and ls2 tb, slp 1 3/4" lt's, slp intake, ud pulley, 91 octane
457rwhp/400rwtq
Old Apr 5, 2010 | 03:00 PM
  #217
TransAm2002
Originally Posted by whiteboy572ci
2001 Z06 Mods:
-Comp Pushrods
-Patriot gold duals
-Vararam intake
-Textralia clutch
-LS2 timing chain
-CCA catch can
-WCC Smooth bellow
392whp/384wtq (NA)
Nice color and name, Brandon.
Old Apr 5, 2010 | 04:20 PM
  #218
whiteboy572ci
Oh no. I assume your names brandon too? We should trade cars then Im going to have the t.b. ported by shaner and open the cutouts on the next dyno and see if i can break the 500rwhp barrier!
Old Apr 5, 2010 | 06:15 PM
  #219
TransAm2002
Yep it is. I am sure you will get the 500 RWHP mark soon.
