So with a bit of good fortune, my car will be back together on Friday.
I'll be heading to Atco Friday night to try it out.
Previous times in the summer heat (+2000ft DA) have been
1.72 60'
about 12.2 at 114mph.
This was done with just a cold air intake, Z06 Ti cat-back, and Hoosier 275/40/17 drag radials.
My new set-up is.
1 3/4 Kooks with off-road X-pipe.
Removed the AIR system.
Powerbond UD pulley (25% - acc)
4.10 Differential w/ hardened uotput shaft and ECS brace
Street Tuned by ECS
I'll say 11.69 @ 117 (And that's not just because your helping me with my line locks). But this assumes you're not bouncing off the rev limiter in 4th at the stripe with those short gears.
It depends on how many passes you get. If you get only one or two runs and it's as hot out as it has been the last few days then you might not even see the 11s yet. If you get three or more passes you should run in the 11.7-11.9 range at over 117mph on at least one pass.
Your stock clutch will now become the real hindrance when seeking the sixty foots and shifting speed that you'll need to reach the car's full potential (which is 11.5s/11.6s at roughly 119mph by late fall/winter).
Yeh, I'm going to have the rev limiter raised to 6500 - even though the LS1 doesnt make any power up there.
Originally Posted by Kurtomac
you wont be that high in 4th with 410s...with 390s i did 128 at only 6200
What size tires did you have with that?
Oh, and 12.3??? Thanks for the vote of confidence
You hit the nail on the head right there. I hope I get enough runs in to be able to get a couple good runs in.
The next thing on my list is a clutch.
I'm kinda surprised it has held up this long (75+ passes). Especially after the glazing I did to it back in November on my third pass ever with the car.
i was just messin with ya capt...they are 26.5 inches...i wanna swap to the 275 hoosiers as welll...they are 25.7 and 2 lbs lighter...should put me closer to the limiter...hopefully at 130 this fall....26.5 is what mt has on their site for the 26 11.5 17 et streets
I think you will go 12.00@116 with a 1.6x 60ft and the clutch taking a dump. Hopefully you will prove me wrong though. Kurt, how were you going 128 in 4th at 6200 with 3.90's? Im at 120 at the end of 4th.
tires grow a lil i think...it was 6200 ish....they are a little bigger than stock sized tires diameter wise....on the dyno with stock wheels/tires i was showing like 132-133 at 6900
