Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Lost HP?
Old Jan 24, 2012 | 09:44 PM
Zosixin's Avatar
Zosixin
Default Lost HP?
Lost 20 to 30 hp
My car is down about 20 to 30hp and about 25tq.
The motor is a ls6 with forged rods and pistons. TF 215 heads and a fast 102 and 90TB. Cam is a 233/239 .
Motor has about 6K miles on it.
It made 448hp and 407Tq on RPM's dyno about 8 months ago. Now it is making 425 and 380.
I put new plugs and wires in it recently and new O2 sensors. The dyno numbers were on two different dyno's out here in Vegas. The low numbers were verified by being down about 3mph at the track.
We made about 6 pulls on the dyno on Monday. Nothing indicates a problem. Fuel is good. It isn't pulling timing . No knock.
Also there is no smoke or oil loss.
The next step would be to do a compression test.
Any ideas?
Old Jan 24, 2012 | 10:34 PM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
my car lose the same then I got my blown engine and that was a 2 years ago! hope it's not the same, it's my the dyno not reading well I still remember a dyno shop we get numbers like 610whp we pick the car out and run at the same night on another mustang dyno we got 586whp.
good luck
Old Jan 25, 2012 | 05:10 AM
vettenuts's Avatar
vettenuts
Do you guys get winter blend fuel in LV? If so, there is the difference. It will be about 5%. I found the same thing with two dyno sessions the only difference being summer vs. winter blend fuel. Once the summer blend came back the power returned to the original level. On my car, the dyno curve was parallel but lower with the winter fuel. If I upped it by just under 5% the two curves laid on top of each other.
Old Jan 25, 2012 | 07:11 AM
Fartpipe's Avatar
Fartpipe
This one can be a mystery for the making. I've had 2 cars do similar things heres what I went through with no answer to why the power loss or trap speed loss.
Compression check
Leak down check
Plugs replaced
wires replaced
cleaned MAF electrodes (Carefully)
changed valve springs
checked for brake drag
changed trans/rear diff fluids
had tuned and retuned
made sure dynoed with same wheels/tires
same dyno every time with same SAE settings
took serpentine belt off and spun all accessories
tried 100 octane gas
ran seafoam cleaner through injection system
checked for intake gasket leaks
tried thinner oil 0w30 vs 5w30
Pretty much only thing left was a possible clutch slippage
Old Jan 25, 2012 | 08:01 AM
pit-man's Avatar
pit-man
I had a loss of power I never figured out. Two different Dynos put my 402 Stroker at 464 rwhp & 465 rwhp, torque was near 450.
Jump to a year later, retune and it shows 445 rwhp, 413 tq. Freaking out, I Checked on another dyno and again on the original...all show 445 area and only 413 torque.
That is 20 lost hp and 37 tq. I take it to the track and I am running as strong as ever. I am actually up 1 mph and a couple thousandths lower ET.
THIS STILL BLOWS MY MIND.
Good luck...hope your is nothing
Old Jan 25, 2012 | 11:18 AM
Zosixin's Avatar
Zosixin
Is it possible the clutch is slipping, and I am not noticing it?
Old Jan 25, 2012 | 12:42 PM
pit-man's Avatar
pit-man
Possible but you would think you could smell it after a couple pulls. A leakdown test may be the only true test.
Old Jan 25, 2012 | 04:13 PM
FNQWK's Avatar
FNQWK
Originally Posted by Fartpipe
Compression check
Leak down check
the above pretty much covers everything. you could just sell and step up to a c6z-Problem Solved!
Old Jan 25, 2012 | 04:14 PM
FNQWK's Avatar
FNQWK
summer vs. winter fuel blend, never thought of that. running 100 oct on the dyno would clear that up
Old Jan 25, 2012 | 04:49 PM
Fartpipe's Avatar
Fartpipe
Originally Posted by FNQWK
the above pretty much covers everything. you could just sell and step up to a c6ZR1-Problem Solved!
YUP I agree with this!
Old Jan 26, 2012 | 04:59 AM
vettenuts's Avatar
vettenuts
I did check the EPA web site. They don't use Butane like we get in the NE to alter the vapor pressure, however they do require other changes to the fuel in the winter months which is stated to reduce mileage. That being the case, if the fuel has less BTU per gallon it will affect the hp. I have done all of this on the dyno a few years ago and if you are making small changes and want to evaluate the results, the fuel can overshadow the numbers. For example, if one installed an UD pulley and then put the car on the same dyno as pre-installation were taken but with winter rather than summer blend fuel, the car will show no gain or possibly negative gain. With a high hp modified car, the numbers can be large (almost 5%). So for a 450 hp car, the hp would drop to around 425 hp.
Old Jan 26, 2012 | 10:09 AM
JoeyOKC's Avatar
JoeyOKC
Have pics of the two different dyno plots?
Old Jan 26, 2012 | 10:18 AM
mchicia1's Avatar
mchicia1
Hmm, I am in PA and have not noticed any dyno # differences from summer to winter.
Old Jan 26, 2012 | 12:33 PM
Zosixin's Avatar
Zosixin
No I don't have the grafts, but they were identical to the others except for being down about 20hp threw the whole pull.
Old Jan 26, 2012 | 02:40 PM
paint it black vette's Avatar
mix to fix also. the right amt of torco to up the octane to what it should be. i use it on race day to keep my detonation safe 1oz per gal is what i blend makes it right for me without bringing the octane up to high. if you mix 8oz torco with 5gal 93 octane supposedly you'll end up around 96octane. check torco's charts if you should use prior to mixing.
Old Jan 26, 2012 | 03:04 PM
Zosixin's Avatar
Zosixin
I dont think it's the fuel because I ran 100 octane at the track. That time is when it traped about 4 mph less.
Old Jan 27, 2012 | 07:34 AM
vettenuts's Avatar
vettenuts
Octane is not the issue, its whether they blend other components as required by the EPA in the fuel you use. Octane is for knock but doesn't control BTU content.
I am not saying fuel is the issue, but I wouldn't rule it out without checking. You could end up spending a lot of time and effort digging into motor issues.
To Lost HP?
