Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
More progress
Old Sep 30, 2012 | 02:05 AM
RonSSNova's Avatar
RonSSNova
Default More progress
Hey gang,
First, credit here goes to Dale, my tuner friend. AKA "CTD" on the forums.
I have re-named him MAF MAN because we are still on a MAF only tune. He has been bound and determined to get the curve good through all 3 gears, especially to get more fuel in the engine in low gear. I've been timing guy, and of course get to sit behind the wheel.
Cooler tonight, but same as 2 weeks ago. Maybe better air? I dunno.
11.18, 11.15, 11.16, 11.100 (damn) and a 11.11 @ 122.83mph.
O the last 3 hits, the car spun so the 60ft slowed to 1.61-1.65. No track prep, and a buttload of FWD street cars. The 60ft on the 11.15 run was 1.58. IAT was 73 degrees.
Here is what's cool. HPT will show delivered engine torque. From 2 weeks ago, same air temp, just more fuel in the engine and less timing in low gear, the delivered torque has gone up 60ft lbs. Right at the stall speed. This is neat tech.
Alan, I believe you are correct. If I get a 60 degree evening, with some track prep, the car will run a ten.
Ron
Old Sep 30, 2012 | 03:12 AM
RonSSNova's Avatar
RonSSNova
Some stuff.
HPT log
Blue line upper chart is mph. The bumps are tire spin.
Green line is RPM
Orange line is commanded AFR which is now set to 12.49:1
White line is the wideband O2
Bottom chart. Red is timing. The flat portions are 22 degrees BTDC.
Purple line is delivered torque.
The big dips right at the hit of the throttle are what I want to mess with next.
Timeslip
Banana
Hope this is interesting, I don't mean to take up bandwidth.
Ron
Old Sep 30, 2012 | 07:55 AM
CTD's Avatar
CTD
Cheater, you never said anything bout the clear corner's & the grills .......looks good
Old Sep 30, 2012 | 08:47 AM
pit-man's Avatar
pit-man
Way to tweak that thing Ron Wither will do you good
Old Sep 30, 2012 | 09:18 AM
Rob Petyo's Avatar
Rob Petyo
I remember being stuck at 11.0's and "Paint it Black Vette" had broke the air for me to run my first 10 sec pass ...
You'll get there!!
http://blip.tv/boostinproductions/am...wheels-2076748
Old Sep 30, 2012 | 10:14 AM
ajrothm's Avatar
ajrothm
Awesome job Ron!
That car is such a sleeper...
HPT has a lot of cool features.. I spent tons of time/money on my turbo bike's logging stuff and its still not near as advanced as HPT/factory sensors.
Keep fiddling and wait for 45* night...you may be at the end of your tire's useful range though...
When you putting it in tha jug? You know it will run 9.80s on a 150 shot spraying out of the hole...
I'm throwing it out there...
Old Sep 30, 2012 | 10:52 AM
pit-man's Avatar
pit-man
You'll get there!!
That is one cool vid...thanks !
Old Sep 30, 2012 | 12:08 PM
RonSSNova's Avatar
RonSSNova
Thanks Dale,
Previous owner did that. But then it also had a wing and spears too.....
Alan, no bottle!
And I picked up some Z06 Speedline fronts for some bigger tires down the road. If they would just spray the track once during the eve, I wouldn't have issues. The tire spin was rather violent a couple of times. I'm glad I put the DTE shafts in the diff. Both sides.
Old Sep 30, 2012 | 05:14 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Nice progress Ron! Now feed it the bottle. You know you want to
LOL.
Old Sep 30, 2012 | 07:38 PM
huggerorange73's Avatar
huggerorange73
2026 Corvette of the Year Finalist - Modified
2025 C6 of the Year Winner - Modified
St. Jude Donor '12-'13
Outstanding!
You built a killer combo sir!
Old Oct 1, 2012 | 08:59 PM
PRE-Z06's Avatar
PRE-Z06
Congrats, skinnies would ensure the 10sec slip just sayin
Old Oct 1, 2012 | 09:27 PM
RonSSNova's Avatar
RonSSNova
Hey thanks guys.
I am casually looking for skinnies and wheel adapters.
Kina be cool to do it w/o though.
3.73, 4000 converter, bigger slicks would be nice too........
And a 383......
NO BOTTLE. Even though I can see a full one from my couch.......
Old Oct 2, 2012 | 07:30 AM
pit-man's Avatar
pit-man
Originally Posted by RonSSNova
Hey thanks guys.
And a 383......NO BOTTLE. Even though I can see a full one from my couch.......
That is all you need to hit the tens NA. But you would probably be mid to deep tens the way you keep at it
To More progress
