Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
New best again
Old Dec 1, 2012 | 12:31 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by 2003VETT
I'm over 3600 in mine! I wonder how much I would pick up I shaved 500 pounds??!
Likely 8s.
Old Dec 1, 2012 | 01:54 PM
98tadriver's Avatar
98tadriver
Originally Posted by baezi z06
exellent mod
congrads on the new best that is very impresive results whith only bolt ons
Baezi
Thanks Baezi
Old Dec 1, 2012 | 06:41 PM
LSOHOLIC's Avatar
LSOHOLIC
Great passes......so your cam + bolt-ons ?? which casting number heads ?
And your weight is impressive....autos are typically heavier......must have got creative with the diet......congrats.....
Old Dec 1, 2012 | 07:16 PM
98tadriver's Avatar
98tadriver
Thank you
Stock cam + bolt ons
Stock 2001 Longblock LS1, 241 castings, untouched
Old Dec 1, 2012 | 10:08 PM
LSOHOLIC's Avatar
LSOHOLIC
Originally Posted by 98tadriver
Thank you
Even more impressive......stock cam and 241's....
And as fast as the solid axle cars...nice.
F-body list......stock with bolt-ons
~1) RUQWIKR -------- 10.685 @ 122.91 (1.37), 01 Formula T400, ATI4600, 4.56, 3060, 03/08
~2) Project_SS ----- 10.866 @ 122.14 (1.45), 98 Camaro SS A4, TCI4400, 3.73, 2840, 03/07
~3) Magnus --------- 10.987 @ 119.31 (1.42), 97 Firebird A4, YPT4400, 4.10, 2920, 12/04
Old Dec 2, 2012 | 12:20 AM
evo2ls1's Avatar
evo2ls1
What mods you considering next? Now tht you have reached the pinnacle of bolt ons. Also what have you dynoed
Old Dec 2, 2012 | 02:00 AM
LS1LT1's Avatar
LS1LT1
True, I too have kept a close eye on those LS1 F-body bolt on ETs (especially as my own Camaro Z28 LS1 bolt on car was always just outside of the main 'top 50' list with it's 11.8s LOL). It took a while but the bolt on Corvettes (C5 and C6) finally caught up.
I believe Ron will be installing a cam and seeking some more astronomical results, but as a cam only car this time.
Old Dec 2, 2012 | 03:28 AM
98tadriver's Avatar
98tadriver
You would be correct sir. going to find the best performing cam to fit my needs next season
I dyno'd 362 SAE thru a locked converter. Locking it usually yields a higher number since there is little or no converter slip
Old Dec 3, 2012 | 10:55 PM
robz's Avatar
robz
To the OP: Nice going.
Those mph's seem low on the f-body list.
I would have thought mid 120's.
Dennis is still king, though.
Old Dec 4, 2012 | 02:52 AM
98tadriver's Avatar
98tadriver
Usually I'm used to hearing the opposite (about the mph) lol.
Old Dec 5, 2012 | 10:55 PM
PRE-Z06's Avatar
PRE-Z06
Congrats, I personally feel your accomplishment is greater than Dennis' even though not as fast because you did it with less cubes, cam and heads even if they're stock lol you're making prolly 40hp less in a car that's slightly less aerodynamic
Old Dec 6, 2012 | 03:32 AM
98tadriver's Avatar
98tadriver
Thank you
I'm just happy that I was able to get into the 10's lol
Old Dec 6, 2012 | 11:41 PM
  #33
LS1LT1's Avatar
LS1LT1
Yes true, but that's a tough call as it's not a true apples to apples comparison either...if Dennis's car had the same level of weight reduction (he still had air conditioning, carpeting, interior panels, cats etc.) I think his car could've possibly gone 10.4s, but that's strictly speculative of course.
3800 stall versus 4000+, 3.73s versus 3.90s as well etc.
Either way though, Ron's C5 still falls under the label/category of 'stock internals' and it did do something that no other C5 has done before nor maybe ever will.
Old Dec 7, 2012 | 09:09 AM
  #34
dennis50nj's Avatar
dennis50nj
thanks Rob but Gary is King and i agree the f-body mph's are low, mostly from the big converters
Old Dec 7, 2012 | 10:19 AM
  #35
robz's Avatar
robz
Impressive all the way around.
It 's hard to eclipse those fbody et's with some of the advantages they have with regard to drag racing.
Old Dec 7, 2012 | 12:04 PM
  #36
LS1LT1's Avatar
LS1LT1
Originally Posted by dennis50nj
but Gary is King
Among all NA bolt ons only Corvettes at least, but technically speaking that Lingenfelter ZR1 (and there might've been one other one?) is the quickest outright bolt ons only Corvette.
True, it's the relatively high stalls that they use as well as aerodynamics that play a roll in trap speed I'm sure and as Rob said they also have some advantages (ie: solid rear) over typical IRS Corvettes as well. Keep in mind that most (if not all) of those high 10/low 11 second bolt ons only LS1 F-bodies are quite gutted/reduced in weight and some even sport Turbo 350 transmission conversions with a trans brake. But yes, I too am still VERY impressed by ANY stock internals/naturally aspirated F-body or Corvette that can find it's way into the 10s as the still very few of us that have done it over the years have often struggled to accomplish.
Old Dec 8, 2012 | 02:09 AM
  #37
98tadriver's Avatar
98tadriver
I can be the king of bolt on C5's
Im gonna go search youtube for that lingenfelter ZR1
To New best again
Old Dec 8, 2012 | 08:54 AM
  #38
dennis50nj's Avatar
dennis50nj
you are the King of bolt/on c5's
Old Dec 8, 2012 | 04:07 PM
  #39
LS1LT1's Avatar
LS1LT1
THAT you definitely are.
And I am the king of all bolt on yellow NA C6s with an A6 transmission under 427 cubic inches LOL.
Here it is.
I still consider Gary's foray into the 9.9s as a little more 'monumental' but this is still quite impressive as well. I thought someone else (LMR maybe?) had also gotten into the 9.6/9.7 range with a bolt ons only C6 ZR1, but maybe not.
Old Dec 8, 2012 | 05:35 PM
  #40
Rob Petyo's Avatar
Rob Petyo
Very Impressive!
I cannot believe the way this thread turned ... why even bring up C-6's, F bodies, 427 Z06's and ZR-1's?
Ron you deserve top spot in my book!
