Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Procharger or turbo
Old Jul 26, 2017 | 08:11 PM
Nick.cerveny's Avatar
Nick.cerveny
4th Gear
Default Procharger or turbo
I have an 02 z06 with a 408 stroker an all bolt ons making just over 500 at the wheels right now. I been debating going with a p1sc procharger or one big turbo. I am aiming for 750 whp with reliability what would be the best choice?
Old Jul 30, 2017 | 01:21 PM
silver408z's Avatar
silver408z
Centrifugal blowers are great for corvettes because of the packaging. You can buy a kit that much easier to install and make power with. Turbo kits will take a lot more fabrication and work to install. Most people do a centi blower because of the ease of installation. With a 408 a p1sc is going to be pretty small. I would do at least a d1sc. Procharger also has a new D1x that seems very interesting. There are also vortecs and paxtons. Talk to a sponsor like A&A about your setup/goals and they will get you what you need.
Old Jul 31, 2017 | 05:44 PM
scott5's Avatar
scott5
With a 408 I'd go D1X
Old Jul 31, 2017 | 06:26 PM
Andyc5vette's Avatar
Andyc5vette
I've got a 408 with a precision 7675 making over 700 wheel on low boost no problems
Old Jul 31, 2017 | 10:57 PM
Nick.cerveny
4th Gear
Ok new question after some research an your inputs I want a procharger. Its between the F1a or the new d1x is the price different worth it?
Old Aug 1, 2017 | 12:48 PM
silver408z's Avatar
silver408z
When it comes to picking the right head unit, you should talk to someone who really knows and I do not sorry. There are so many options and differences That I couldn't even tell you. F1a, f1a-94, d1sc, d1x and that does not even get into the other brands. Talk to a shop like A&A or even the manufacturers like Procharger.
Old Aug 3, 2017 | 10:59 AM
algZO6's Avatar
algZO6
A&A YSI with 8 rib and DD. 1000 at the wheels all day. No need to reinvent the wheel.
Old Aug 3, 2017 | 11:55 AM
Volk2142's Avatar
Volk2142
Did you fab the manifolds for that set up? f did you use the hinson hot pipes?
Old Aug 4, 2017 | 01:14 PM
Roddy13's Avatar
Roddy13
Tell us more
Old Aug 4, 2017 | 04:02 PM
algZO6's Avatar
algZO6
Originally Posted by Roddy13
Tell us more
What more do you need to know?
Old Aug 4, 2017 | 04:10 PM
Roddy13's Avatar
Roddy13
Everything. I don't see a build thread by you? Car sounds impressive. Photos?
Old Aug 4, 2017 | 04:14 PM
algZO6's Avatar
algZO6
Do a search and you will find one. It's nothing magical and many have done it.
Old Aug 4, 2017 | 04:23 PM
Roddy13's Avatar
Roddy13
..Dreams crushed. Thought 1000hp would be magical. (goes back to drawing board to figure out life).
Old Aug 4, 2017 | 04:36 PM
algZO6's Avatar
algZO6
No worries, if you can't figure it out you can always live through others.
Old Aug 4, 2017 | 05:32 PM
Roddy13's Avatar
Roddy13
Do you have a guide book on living this vicarious lifestyle?
Old Aug 6, 2017 | 10:20 PM
StingrayRebel's Avatar
StingrayRebel
if you go with a centri use an a&a bracket regardless of what blower you use, it's the best one out there for these cars and their customer service is also top notch
Old Aug 8, 2017 | 07:14 PM
GARY2004Z06's Avatar
GARY2004Z06
My buddy Andrew's true DD that's blown.
ET will drop a little more this season.
Originally Posted by Capthuff
That's right! Andrew went through 5 rounds to win the 10.0h index class this past weekend!
It's a very competitive class with 30 cars this time - which is typical for the atco indexes.
Shifting Gears in a street car!
Congrats buddy!
Would be nice to see some more of the corvette crowd join the fun.
Still the same.
C5Z. Forged 346. YSi. T56. C6Z rear.
Hoosier 28" QTP.
Stock Ti cat back. Yep. Stock mufflers...
To Procharger or turbo
Old Aug 16, 2017 | 05:45 PM
lilryan's Avatar
lilryan
I would go YSI if i were starting over again. Proven combo.
Old Aug 29, 2017 | 07:07 PM
gnharley's Avatar
gnharley
I'm already convinced centrifugal , probably A&A , is the way I want to go but I have a question about stroker cranks, I have never seen anything between the stock 5.7 stroke & 4.00" other than the obvious(more cubic inches with 4") is there some reason no one has ever done like a 3.75" 3.85" or somewhere in between 4.00 " Maybe it's been tried & just aint worth it ? Probably would cost just as much for anything over stock , I suppose , just wonderin'........
Old Sep 4, 2017 | 10:54 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Primarily due to all the success with readily available 3.622" and 4.00" cranks. No reason to reinvent the wheel.
Two of the most impressive supercharged combos on here are Andrew's posted above and algZ06 also posted above.
A 408/YSi would be a nice package.
