Front view camera
Is there a front view camera that I can use with my iPhone.
Thanks |
Originally Posted by 9t6t7
(Post 1594976211)
Thanks |
(Post 1594976211)
Thanks You need to purchase a $20 camera and a device called NAVTOOL. You install it your self and it can be done in 3 or 4 hours. I have it in my 2014 and it works perfectly. It also streams my iPhone to the NAV screen if I want to do that. Humongous thread that shows the installation and the camera to get. There is also the ability to hook up side cameras that come on with the turn signal. I just use the front camera, the OEM rear and have the capability to stream if I want it. https://www.corvetteforum.com/forums...tallation.html Elmer |
Cheap Front Camera
There is thread on this forum that has complete instructions and product info to install a cheap front camera that works with iPhones and Android phones. The whole system cost about $75 and works really well. Here's the link.
https://www.corvetteforum.com/forums...nt-camera.html |
Originally Posted by Bob Beroza
(Post 1594976933)
What would happen if you used the $20 Pyle camera that gives the correct image on the video and has grid line option that is set with a simple wiring option? Did you eventually use a different camera for the wireless system? The only system that gives the video to the NAV screen and turns on/off automatically is the NAVTOOL. It also can be turned on/off anytime you want by pressing the "Back" button and holding it for 3 or 4 seconds. The wireless system is cheaper. I'm not seeing any other advantage to the wireless except you don't need to run a wire inside of the cabin. http://www.ls2.com/forums/images/smilies/shrug.gif The wireless system will definitely get video to the driver in the cabin but not on the NAV screen. Is that a fair comparison? Elmer |
