Cross over setting
I have upgraded the speakers in door and rears to ts a878 and ts g520. Now my kenwood kmr-d372bt now the radio has these setting in the setup.
xover tweeter frq 1khz to 12.5khz front hpf 30hz to 250hz slope -60db to -24db Rear also has these setting. Question is what should these be set at? Also I ask about low volume at rear speakers this week when off will try and adjust pots on roem vet 1 a little better. Thanks for any ideas |
You need to leave the front cross over off since it also feeds the factory sub amp. The 3.5" has a built in high pass capacitor.
The rear can be set around 50 or 60 hz. |
Originally Posted by VinceC5
(Post 1599151797)
You need to leave the front cover off since it also feeds the factory sub amp. The 3.5" has a built in high pass capacitor.
Originally Posted by sirdano
(Post 1599152670)
What do you mean by front cover? Also should I enable subwoofer?
Leave subwoofer disabled until you add a dedicated amp and sub. This control your sub one-out. (RCA jacks) |
Hey thanks for the help and the diagram make sense now. When I am off this week going to try and adjust roem vet1 like this.
https://www.corvetteforum.com/forums...roem-vet1.html See if this helps equalize the sound between front and back. Could be like some have said the base is over powering everthing |
