What did you do to your C3 today?
Here's a "before" pic-
DSCN0661 by Richard Hayes, on Flickr
Keep in mind we moved about a year ago and we are packrats who still havent fully unpacked,
Found welder...cant find hood cant even find cheesy hand held mask thing that came with welder then ADD hits and i start hunting the power steering pump and lines...lol 2000sq ft basement and its hiding really well..ooh found stock tail lights and bubble lenses that i didnt know i even had...so took break gragged a tea and dropped by here....
When the radiator was out I figured that it was 45 years old an while it was out I would send it out and get it checked out and serviced before I put it back. I also thought it would be the time to replace all of the hoses. Then I also found out how much fun you can have changing the heater hose that goes up behind the evaporator for the air conditioning. One of the clamps was facing toward the plastic housing of the evaporator and not possible to get a socket on.
I have had three different coatings on two different sets of headers. Rust bleeds through the coatings eventually.
Here are the some pics of the primed and painted stages using VHT products.
After numerous ideas and Google searches- I found some stainless steel trim- with glass for about $17- used by people who restore/build clocks !!! Apparently in the UK it's a big hobby.
Just had to cut the hinges off- remove the dial- and the worked perfectly!!!
Worked out the bugs and the things that bugged me!!!
I decided to turn the injectors around- and clean up the center on the engine . The Plugs were just to big- and left no room for a fuel rail brackets - so I modded the connectors!!
on the left is the OEM- right is the modded one-
Before-
just under an inch
After- not quite a 1/4" but that's all I needed-
rewire...
split loom- just not quite the look I wanted-
½ Copper pipe- cut on the table saw-
Looked at plastic- but figured this would be a little more heat resistant-
looks good...but-
How about some textured paint to match the throttle bodies?
neatened up the fuel line hoses- Just need to run the wires underneath the intakes - and It'll be all hidden.
Mainly redoing the wiring for plenty of clearance for the throttle linkage- and redid the regulator to give plenty of room
Details- countersunk some hex heads in Wilwood cover-
Now Jim- That's FUNNY!!!
Thank you Shannon- the only thing that gets old- is it's still in the garage- been there so long the tires look like old potatoes and have started spouting roots!!!
OK- more gauge work-
Just got the Oil temp gauge made by Roger at Corvette Instruments- He did a great job. I really needed a gauge to see what the temps are going to be running in the Dry sump tank.
Sort of tough to tell- but I went w/ a brushed look on the faceplate. The old clock button will be an over ride for the electric fans to turn on.
The symbols (Battery/Radiator) were what I had laying around and temporarily taped in place. But I like the look so I'm gonna go to the junkyard and find something for the door ajar and the headlight (probably off a Miata). The battery for ignition/alt and the radiator is when the electric fans are running.
On the engine- went with new AN lines and fittings- as I was able to minimize the number of fittings and by going w/ 90º pan fittings and have some extra clearance from the exhaust. I also when with Earls' "Flameguard" to help with heat.
Pressure checked the hoses first w/ my homemade tester-
125PSI and no leaks-
Polished the pan while I was at it...
more clearance Clarence.... now I can drop my tacked up exhaust and get it looking good-
I like the black hose and polished ends...I even got another 10ft and will re-purpose the old fittings. As I'll use it to 'hide' the electrical wires. Hope it'll look a lot better than split loom!!!
I even had some knucklehead in an Oldsmobuick decide he wanted to give her a try. Smoked him off the light but had to let up as I ran up on the car in front of me. I'm sure he thinks he pulled out on me, but my 350 horse girl and I know the truth!
Sadly, the weather is supposed to get poopy tomorrow so she's back in the garage until the next spring-like day.
